Sry about this, wonder if someone can help me. Need to replace the rear hose on a set of Juicy Ultimates. I Know that if i buy the bleed kit from Avid i get a set of Olives and fittings for the lever end, but i'm not sure about the calliper end. The adjustable Banjo type bit that is on the end of the hose, does this use the same fittings as the lever end or do i need to buy something more?
I know I can replace hoses on brakes and have the bleed kit, but got a quote from a LBS to lenghten a second hand set of brakes I got. Turned out to be cheaper than buying the hose and olive kit from CRC and doing it myself! - just a thourght...?
If you buy the Avid hose then the fittings are included..not easy to find the hose in stock anywhere though...
