Bike shop says DOT 3 or 4 Avid seem to point at Dot 5.1
Confusion rules!!
Any ideas?
Thanks
Posted : 05/08/2009 12:46 pm
Depends on the brake
Posted : 05/08/2009 12:49 pm
4 or 5.1 will be fine. 5.1 has a higher boiling point so should fade less quickly. The 2 fluids are interchangeable. I use 5 in my juicys.
Posted : 05/08/2009 12:50 pm
Cheers - I'll use 5 then
Posted : 05/08/2009 12:59 pm
Use either Dot 4 or Dot 5.1.
Don't use Dot 5 as that's different stuff to 5.1 and will wreck the seals.
Posted : 05/08/2009 1:01 pm
5 won't wreck the seals, it's DOT rated so is compatible with any other DOT rated component,it just doesn't mix with the others as it's silicon based.
Posted : 05/08/2009 3:17 pm
O.K. Just back from the shops with dot 5.1!
Job done
Posted : 05/08/2009 4:03 pm
