Avid juicy 7 :- Cha...
[Closed] Avid juicy 7 :- Changing 185 rotors for 203....Post mount... Advice please
I am changing to bigger rotors on a RS Revelations so PM 185 to 203. I have the required adaptor but will i need shorter bolts? After fitting the adpater to fork the bolts that attach to caliper look to long.Do i need shorter bolts an if so where do you buy them??
Posted : 17/04/2012 9:35 pm
The adapter didnt come with bolts?
Which (make/brand) adapter did you go for (the 203 one)
(am also going to go from avid 185 post-post adapter to a 203 post-post sometime soon)
Posted : 17/04/2012 9:38 pm
Yeah, the Avid 185 PM adaptor bolts go right through the adaptor, the 203 ones are separate, just normal 160mm PM bolts I think. Pop down your LBS, they'll probably have some kicking about in a spares box if you ask nicely.
Posted : 17/04/2012 9:41 pm
yes came with bolts which attached adapter to post but then existing bolts needed to fix caliper to adapter looks far to long?? got adapter from superstar components £4.95)
Posted : 17/04/2012 9:45 pm
