Avid juicy 5 changi...
[Closed] Avid juicy 5 changing hoses
Just went to change the hoses,attempted to undo the bolt the cable slots into at the lever end and rounded the bolt!! now is it just stiff or am i missing something dont want to attempt the other till i get some advice
Al
Posted : 13/04/2011 10:11 am
They're not reverse thread, if that's what you mean.
Definitely should just unscrew in the normal way.
Posted : 13/04/2011 10:35 am
 nuke
Yep, should just unscrew normally. Maybe a bit corroded/rusted depending on age...I know my Juicy 5s have some rust/corrosion around there.
Posted : 13/04/2011 10:37 am
well thats reassuring didn't want to plough in and round the other one
with my ahem...excessive brute force
another thing can i re use the olive and barb or are new ones required?
Posted : 13/04/2011 10:43 am
New ones (Olives deffo, might get away with re-using barbs). I'm sure all the info you need is in that youtube link.
Posted : 13/04/2011 10:50 am
 nuke
New ones advisable although I'm sure someone will come along and say they have re-used them.
Posted : 13/04/2011 10:52 am
Cheers DezB
i'll have a look later youtube blocked on the work computers
Al
Posted : 13/04/2011 10:53 am
