Avid hose shortenin...
[Closed] Avid hose shortening and bedding pads in advie please
As per the thread below, i will be getting some Avid Elixir Rs tomorrow.
I need to shorten the hose but have no bleed kit yet, can i do it like with shimano? I.e. Remove pads and pump pistons out a bit, cut hose at lever end and insert new barb and olive, screw together, open reservoir cap, push pistons back in, refit pads?
Also - regarding bedding in - what is the best method (not just go and ride) - i am talking for bite and longevity of pads.
Cheers in advance
Posted : 08/04/2010 8:19 pm
Based on my experience of building quite a lot of bikes equipped with these brakes, most of them benefit from a proper bleed to start with. I'd suggest getting one of the kits that somebody on here mentioned over the last few days and spend a bit of time getting them right to start with, it's worth the effort(worth spending the extra time getting the calipers perfectly aligned too).
Posted : 08/04/2010 9:31 pm
There's no resevoir cap to remove - the way to bleed them is a lttle different. Bite the bullet and buy the pukka bleed kit
Posted : 08/04/2010 9:35 pm
On the off chance your near Lichfield I've got a kit. ๐Ÿ™‚
Posted : 08/04/2010 9:44 pm
i am not a million miles away so may take you up on it ๐Ÿ™‚
Posted : 08/04/2010 10:46 pm
