Avid Elixir rear ca...
[Closed] Avid Elixir rear calliper mount question
Swapping rear 185mm Avid rotor to 160mm - should I order an Avid adapter as well or will my old Hayes/Shimano (160mm) one do the trick?
Thanks
Posted : 14/03/2010 12:45 am
As long as you use a 160mm IS (on the frame) to Post (the calliper) mount it does matter who made the mount or the calliper.
Posted : 14/03/2010 12:48 am
as above,you beat me to it ๐Ÿ˜‰
Posted : 14/03/2010 12:50 am
Even with the cup and cone washers that Avids use?
Posted : 14/03/2010 12:59 am
 br
Yes, as they space out from a standard mount.
I use Hope or Avid depending on which disc does on, still use cup/cone.
Posted : 14/03/2010 12:28 pm
Cheers ๐Ÿ™‚
Posted : 15/03/2010 8:10 pm
