avid elixir r fitti...
[Closed] avid elixir r fitting to inbred problem
im stuck, trying to fit a pair of elixirs to my inbred and need to slot the hose through the guides. I have taken of the casing and removed the hose from the lever, but cant seem to remove the barb and the compression fitting. Anyone any idea how, is it a screw fitting or just a push in, there is no allen key fitting on the end, and they are the latest set of elixirs. thanks in advance
Posted : 04/06/2010 9:14 pm
i am not to sure but i think you will need a new barb and olive. Then cut the hose then rebuild them.I tried to remove a juicy three but i couldnt get it off so just cut it off
Posted : 04/06/2010 9:19 pm
The allen key fitting seems only to be on the replacement barbs. You will indeed have to cut it off and replace with new olive & barb. Try not to re-use an olive - not worth the risk. Try lbs or crc for replacements.
Posted : 04/06/2010 10:02 pm
