Help please! If I had the money i'd swap these bloomin avid brakes as I don't rate them very high but I cant so I must keep using them and have a slight problem only with the rear after fitting new pads. They rub on the disc a bit and I've tried pushing the pistons back as far as they will go but still they rub. Is there an easy solution? I read online about removing some fluid but wouldn't know where to start on that. Help!
Thanks in advance
Posted : 15/04/2014 5:15 pm
Removing the fluid is very easy. Undo the bleed port (probably won't even have to fully remove it) and hold a rag right under it, push the pistons back and put the bleed screw back in.
Posted : 15/04/2014 5:28 pm
Ah brill, thanks for the help, hopefully that should stop me swearing at them for a while!
Posted : 15/04/2014 7:28 pm
