Avid Elixir 2012 - ...
[Closed] Avid Elixir 2012 - Reliabilty?
I'm considering a set of 2012 Avid Elixir 7s an want to know how people are getting on with them? Are the proving to be reliable ?
I'm not interested in another buy shimano or formula or hope thread... I would just like feedback on the latest model of Elixirs.
Posted : 25/11/2012 11:15 am
Mine have been fine but LBS told me they have had to send back a number of sets for pistons sticking
Posted : 25/11/2012 11:37 am
elixer brakes are pretty much bullet proof, most of the problems you hear of are from garden shed "mechanics" that can't bleed them properly.
Posted : 25/11/2012 11:53 am
They will certainly need bleeding out of the box, pretty much all Avid owners will tell you that
Posted : 25/11/2012 12:09 pm
Got some on my bike, but they came with some really shite OEM type levers. Managed to bang them into a tree stump and replaced them with the "proper" ones which feel way better.
Cannot fault the braking though. Have used them in all conditions and they have been great.
Posted : 25/11/2012 12:18 pm
So once bled they stay good? I had a set of 2010 Elixir Rs which tended to go off after a few weeks of riding hence wanting to know if the reliabilty has improved.
Posted : 25/11/2012 12:22 pm
I've got Elixir 3's that were fitted to my bike from new. So far they've been completely faultless, though I've only been riding it from March. Just not looking forward to bleeding them as it looks a real convoluted process. I have heard that they need bleeding more regularly than others, but I'm not sure if this is true or not.
Posted : 25/11/2012 12:26 pm
Elixir R would be an OEM brake built specifically for Spesh I'm guessing?
I have had X0 and now have X0 Trail and they have been flawless. The feel & power from the X0 Trail is fantastic. Couple of friends have them too and really rate them as well.
Have bled them once when I trimmed the hoses and that's all they've needed.
Posted : 25/11/2012 12:32 pm
FWIW I also found mine improved once the OEM pads were replaced
Posted : 25/11/2012 1:01 pm
My elixir R's have be awesome and the levers are adjustable without tools.
Posted : 25/11/2012 1:12 pm
i've got elixr 3's. They need bleeding regularly which is dead straightforward but i'm finding them a PITA to get set up right and had to ride yesterday with an annoying squeal after putting my front wheel back on after the car trip.
They will be replaced when i can afford it, not for reliability but for feel which i can't get on with. I want to pull the lever and it do what i want it to!
at the other end of the scale my friend has codes and loves them. Don't need much bleeding and easy to set up. good feel as well
Posted : 25/11/2012 1:46 pm
Fluid control braking only needs bleeding when there is a problem like leaking fluid or if they haven't been bled properly in the first place. When bleeding the same principle applies to any fluid brakes. Make sure there are no minute air bubbles in the system. Admitted its easier on vehicles than bikes but even a few microscopic bubbles can be problematic. Most people don't realise that they are the ones putting the bubbles in in the first place by not letting the fluid completely settle an dissipate the air.
Posted : 25/11/2012 2:13 pm
I've got Elixer's on both bikes. They're great brakes but you'll need a bleed kit. Having said that, it's a 5 minute job
Posted : 25/11/2012 3:02 pm
Like I said if you need to bleed your brakes more than very few years you've got a leak or air in the system. ( leak or bad bleeding ).
The higher the dot rating the less you'll need to bled as the fluid is high performance.
Posted : 25/11/2012 3:32 pm
I've used them for three rides now and they seem to be far improved on the pervious version - feels more powerful than deore m596, the levers suit my hands better and the integration with the reverb lever is fantastic.
Time will tell if the reliability issues are resolved.
Posted : 02/12/2012 6:37 pm
i had some c09 elixer 5s which were faultless out of the box untill i sold the bike this year, never bled them.
the elixer 3 has a juicy caliper so a different brake.
Posted : 02/12/2012 6:41 pm
Hi cant comment on the 2012 version but I have 2 sets on bikes I own. A set of Elixr Rs and a set of CRs on the other.
The R`s I know I have never bled and were bought second hand work very well, dont squeal, drag, or go soft and they are top loading pads so pretty simple.
The CR`s were new in 2009 (i think).
I`m not sure I think I have bled them once, they have had a lot of use. Trips to Scotland, a lot of wet muddy lakes riding and next to no maintainance. They could do with taking off the bike, cleaning fresh pads and a bleed and im sure they would be good as new. There is a little play starting in the pivots of the carbon levers but its no biggee.
If the new model is as good as the old I wouldnt have a problem using them.
Posted : 03/12/2012 9:17 pm
The reach adjuster on mine are both goosed after less than a years use. Otherwise great brakes but the levers now flop about between on and off (if that makes sense)
Posted : 03/12/2012 9:52 pm
My Elixir R's have been fault less. Didn't even need bleeding out of the box!!
Could do with bleeding now though, 2 years on, maybe this is where the problems start.
Posted : 03/12/2012 11:13 pm
