Avid 185m Rear Post...
[Closed] Avid 185m Rear Post Mount Adaptor question (Turner DW)
This may be a daft question but are front and rear post mount brake adaptors interchangable?
Just got a DW 5 spot and the rear brake is post mount.
I use Juicy 7's with 185mm rotor and can't seem to find a specific rear adaptor to suit.
Posted : 19/08/2010 8:40 am
yes but deduct 20 m whe you swap to rear
180 f 160 rear for example
I will text you the bike tart insult...credit crunch clearly biting then ๐Ÿ˜‰
Oh scrap all that advice is for IS no idea re Post mount perhaps post is 140 rear
Posted : 19/08/2010 8:46 am
Erm yes, thanks for that johnnie ๐Ÿ˜•
Posted : 19/08/2010 8:58 am
I am here all week with advice like that ๐Ÿ™„
Posted : 19/08/2010 9:00 am
I would think this would fit even though its for the front as the calipers are interchangable - this is what I used on the front of mine as the IS adapter on teh the front is IS to 160 so I just bolted this ontop :
http://www.chainreactioncycles.com/Models.aspx?ModelID=13717
Yup I am right:
http://www.artscyclery.com/descpage-AVAPA185.html
Use this adapter to mount any Avid caliper with a 7" (185mm) rotor to a frame with Post Mount mounting tabs. Does not work with International Standard tabs. Works for both front or rear brake applications
Posted : 19/08/2010 9:07 am
Foxy - you're a star ๐Ÿ˜€
Thanks very much, I'll nip into Merlin at lunchtime, they should have one in.
Posted : 19/08/2010 9:22 am
