Are there actually ...
[Closed] Are there actually any fun 4” sus frames?
if you are breaking such a frame on jumps and drops then you need to smooth out your riding style, or ride a hardtail for a while to figure out how to ride smoothly.
Or pick the right tool for the job!
Posted : 24/06/2011 3:34 pm
Can only echo what others have said and recommend the Blur 4x - fantastic bike.
Am about to sell my Large ano silver frame too, just have to finish replacing the busings & bearings.
Posted : 24/06/2011 3:37 pm
Spitfire double discount ?
Posted : 24/06/2011 3:38 pm
 Mike
Reading this I'm regretting ever selling mine...send me some details of yours please honourable george 😉
Posted : 24/06/2011 3:40 pm
I've just slackened a Pace RC405 by two degrees using a custom-made angleset, but you can buy them off the shelf. Seatpost angle doesn't get screwed as it would using a longer fork, drops the bottom bracket slightly, needs a shorter stem to keep the steering usable and it's made it feasible to chuck a black-boxed 150mm coil u-turn Sektor on the front.
Totally changed the feel of the bike, much more stable downhill, still a really good climbing bike.
Anyway, my point is that with the ability to tweak head angles, you can be a load more creative with frames, you're no longer stuck with the manufacturer's chosen geometry - you can modify things to suit your own preference. So you could take a shorter-travel trail bike and slacken it off a bit, bang longer forks on without screwing up the weight distribution and seat angle and so on.
Works Components do a whole bunch of angleset type things to fit various headtube configurations, so you, for example, take a Trance and make it slacker and use a longer fork for a bit more amusement in a way that would be horrid with the original angles.
Anyway, just a thought.
Posted : 24/06/2011 3:52 pm
As a partial compromise, can you fit a wider rim and bigger tyre in the back of the BFe? Otherwise a Blur 4X and a long seatpost makes sense.
Posted : 25/06/2011 12:12 am
Could I have some details on your blur please honourablegeorge
Posted : 25/06/2011 12:37 am
I have a long blur 4x and am 6'3". Its a bit cramped on long climbs but not too bad. Most fun bike i've had coming down. Anything bigger than a 2.25 advantage won't fit in the rear.
Morewood ndiza looks none too shabby either.
Honourablegeorge, you are bonkers. Keep it.
Posted : 25/06/2011 12:40 am
Foes 4X or XCT2:1
Posted : 25/06/2011 6:48 am
 jedi
transition double all the way
[url= http://www.flickr.com/photos/ukbikeskills/5857959102/in/photostream ]VIDEO[/url]
Posted : 25/06/2011 7:50 am
 st
Some of those frames would be ace if I was a bit shorter. I guess the question should be what are the 4" equivalents to a large BFe??
The Foes XTC looks nice but the top tubes look like they were designed for people with stumps for arms and a max 2.2 tyre on a modern 'trail' bike, really?
Posted : 25/06/2011 8:36 am
Someone mentioned the old Enduro SX - my son has outgrown his Hardrock so wanted another bike and was keen on taking my BFe. To distract him I build this up from the spares bin:
It's not light but he thinks it's cool and fun, which seems to be more important to a 15-year old!
Posted : 25/06/2011 1:10 pm
Lucky 15 year old!
I used a Kona Howler for 2 to 3 hours razzing round the local woods and FoD. It was awesome fun and I took it to Cwmcarn for uplift days and entered miniDH too. Ran it with a coil shock and Pikes up front wound up or down depending on what I was doing.
Posted : 25/06/2011 1:59 pm
 st
Nice ideas but they seem to he straying into the "mini DH bike that you can haul around on longer rides too" kind of idea. Been there, done that and it didn't suit.
Posted : 25/06/2011 3:04 pm
Seriously, a [url= http://www.morewoodbikes.com/bikes/xc-marathon/zula/ ]Zula[/url] is what you want.
Comfy enough for me to ride 38 miles on the road, light enough to then cycle up Dumyat, and stong enough to withstand my ham-fisted point-at-the-bottom-and-hope effort at bombing back down.
Posted : 25/06/2011 3:12 pm
 ianv
You could try and find one of the original 4" travel hecklers (for next to nothing probably). I did everything on mine: alps/bike parks etc. Pretty sturdy and work well with a 130-140mm fork. Only problem might be tyre clearance but you can definitely get 2.35 high rollers on one
Posted : 25/06/2011 4:55 pm
There's also the lesser known but incredible value YT indestries Play bike (100-130mm travel) - £1600 full bike:
http://www.yt-industries.com/
it'd need a long seat post for 'proper rides' but the long version has a 590 tt length so it shouldnt be to bad.
Posted : 25/06/2011 5:18 pm
I'm probably miles off the mark in the other direction but there's the [url= http://www.specialized.com/gb/gb/bc/SBCProduct.jsp?spid=52783&scid=1000&scname=Mountain ]Evo version of the Specialized Epic[/url]. It still has 100mm at the rear but the Evo bit means 120mm forks, so slacker head angle, wider bars, uppy/downy post etc. Some review I saw of it raved about it but it's definitely a short travel trail ripper rather than a play bike.
Posted : 25/06/2011 5:41 pm
Mythic Rampant
Posted : 25/06/2011 7:08 pm
[pub banter style post]
st - what have you tried before that felt dead and not what you're looking for? And anyway, I thought BFes were meant for razzing round the woods and jumping and dropping and general DH style tomfoolery. Do you run yours with SIDs up front or something?
Maybe have to up to 120mm and look at Trek EX or Yeti ASR5 - more in common with trail bikes than XC whippets.
Posted : 25/06/2011 9:01 pm
tomglass20 - Member
Tom - it's an anodised silver large Blur 4x frame, a Fox RP23 shock (upgrade over standard), I bought it in November 2006.
I've serviced the shock (new fluid, replaced all the seals) and have replaced the bearings, fitted new bushings and shock mount (well, I will - I have the tool, the bearings, the bushings and all the rest, just need to find the time).
Frame has the usual bit of cable rub and scuffs, but in good nick. I'm in Ireland, but I can probably ship it for free.
Posted : 27/06/2011 9:25 am
honourablegeorge - how much are you after for the frame?
Posted : 27/06/2011 9:36 am
Those yet-to-be-released Ragley's sound more like the thing.
Posted : 27/06/2011 10:13 am
slight hijack but my kona dawg will be going on the classifieds this evening. Its an 04 frame so 100mm travel rather than the bigger travel of later years.
putting pikes at 140mm on the front slackened it our slightly and its been great fun to ride, from twisty singletrack to the Nevis Red DH. Let me know if you're interested, otherwise it'll be on the classifieds soon anyway
Posted : 27/06/2011 10:21 am
Definition of a fun 4" full sus:
Posted : 27/06/2011 10:26 am
Hob Nob - Member
Not sure what they're selling for, tbh. I'll have a trawl through the EBay listings once I've finished sorting it to figure out a fair price.
Posted : 27/06/2011 11:07 am
Seem to go for about £500 usually mate.
Posted : 27/06/2011 11:34 am
Based on how much fun I've had with my Mondraker Foxy, I'd suggest taking a look at the 2011 Factor (120mm little brother of the aforementioned)
[url= http://singletrackworld.com/reviews/premier-mondraker-factor-rr/ ]singletrack review[/url]
going by the above, I'd consider better tyres and a shorter stem though
Posted : 27/06/2011 11:35 am
 momo
Another 4x recommendation from me, here's mine:
Posted : 27/06/2011 11:40 am
Santa Cruz Blur 4x or (if, like me, you are fairly light and don't need the heavier weight tubing) Blur Classic. Less racey geo than the Blur XC, 115mm of travel, takes a 120mm+ fork well as the original angle is quite steep so a longer fork (I run a Classic with DT Swiss XMC130) just brings the geo to current norm.
I don't really want more rear travel, it would just slow me down in southern england and even trips to more XC-oriented trail centres like CYB would see a trade-off from more rear travel. Whereas I have found the longer travel front end really helps speed and security on the rough, with no real disadvantages (especially with the Launch Control, which takes out half the travel for climbing/roads).
Usually plenty of Blurs about for sale SH in decent nick - I sought out a decent condition, post 2004 (when tyre clearance was made sensible) Classic.
Posted : 27/06/2011 5:43 pm
Liking the 4Xs with 36s up front. Only had Pikes on mine.
Posted : 28/06/2011 3:31 pm
I ran mine with 140mm Thors for about a year and it was excellent but just wanted something a bit more loony! Fits the bill perfectly and I've noticed no trade off in terms of climbing ability but on the descents its flippin crazy!
Posted : 28/06/2011 3:42 pm
Right - my 4x frame is now totally play free, new bearings, new shock mount, replaced a pivot axle, cleaned it, new seals in the RP23.
I'll stick it on the classifieds.
Posted : 04/07/2011 4:21 pm
 jedi
my mate lairy nick does everything on his transition double!
if it had front mech guides i'd have one 🙂
[url= http://farm6.static.flickr.com/5078/5857408823_7a5822bf45.jp g" target="_blank">http://farm6.static.flickr.com/5078/5857408823_7a5822bf45.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ukbikeskills/5857408823/ ]DSC04284[/url] by [url= http://www.flickr.com/people/ukbikeskills/ ]ukbikeskills[/url], on Flickr
[url= http://farm6.static.flickr.com/5072/5874495956_c39d940797.jp g" target="_blank">http://farm6.static.flickr.com/5072/5874495956_c39d940797.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ukbikeskills/5874495956/ ]DSC04665[/url] by [url= http://www.flickr.com/people/ukbikeskills/ ]ukbikeskills[/url], on Flickr
Posted : 04/07/2011 5:50 pm
Page 2 / 2
