Are Mavic 819'...
[Closed] Are Mavic 819's OK with a 2.2 RQBC
 SOAP
As above really, I'm concerned with width and tyre roll.
Got a cracking deal with CK Hubs.
Posted : 16/02/2014 7:51 pm
No, you'll die.
It'll be fine! Wouldn't personally have Kings on 819s though, better rims and hubs for the money IMO!
Posted : 16/02/2014 7:53 pm
I use 2.35 fat alberts all the time on xm819s and I'm still not dead.
Posted : 16/02/2014 8:00 pm
My exact setup, no problems with roll as long a you keep the pressures sensible.
Posted : 16/02/2014 8:14 pm
Got mine set up tubeless on narrower mavic rims so they should be fine
Posted : 16/02/2014 8:17 pm
I had a 2.4 on mine at one point, that was a wee bit much but still worked not too bad. 2.2 was fine. They can be a little bit roll-ey but that was the same on my Flows so it's not a rim width thing, I think it's just a big-tyre-with-sausageskin-sidewalls thing.
Though njee is right too.
Posted : 16/02/2014 8:35 pm
Thats my set up too, I've had a couple of issues with the side walls on the rubber queens but I don't think its down to the rim/tyre combo. The supplier said the conti side walls aren't the best.
Posted : 16/02/2014 8:37 pm
 SOAP
Good stuff ...They have never been used and he wants £300 . Got to be worth it.
Posted : 16/02/2014 10:48 pm
sounds like a pretty good deal. go for it!
Posted : 16/02/2014 10:49 pm
SOAP - Member
They are heavy compared to the 719, a PITA to build from a mate in the LBS's advice. Considering the 719's run tubless with 2 wraps of stans tape I'm not convinced there worth it.
Posted : 16/02/2014 10:56 pm
You'll be fine - I run 2.2 RQBCs with my 719s. I'm not dead yet.
Posted : 16/02/2014 11:33 pm
