Are the cast lowers/ legs on all Marzocchi 32mm bolt through forks able to be swapped from one fork to another?
I have a pair of '07 Z1 Sports with a snapped disc mount and newish internals and a pair of ' 05 Z1 Freeride with worn stanchions and iffy internals and wondered if i could make a good pair out of the two?
Anybody tried this?
go crazy. give it a go....
bodge em on, see what happens
Thats what im thinking, but thought id ask before i go and break both pairs ๐ฏ
I shall report back in.. well after a lot of swearing ๐
have a look at the following generally if the spring type stay's the same say coil to coil should be simple it gets more complicated swaping from coil to air as the seals are different http://www.wheresweyland.com/mountain_biking/110/2006_marzocchi_service_manuals/
