Are Fox and Rocksho...
[Closed] Are Fox and Rockshox rear shock mount kits identical
Hi as title really - ie would a Rockshox mount kit fix a Fox shock
They seem to be the same part(e.g at TF) but I found the below on t'internet
"Same nominal size, but the tolerances vary. RS eyelets are usually on the small side and Fox on the big side.
So Fox hardware in a RS shock would likely be hammer-fit (tm) and RS hardware in a Fox shock would likely be loose enough to knock."
so - anybody any experience ?
ta
Posted : 04/07/2015 6:10 am
