are disc brakes rea...
[Closed] are disc brakes ready bled?
When you buy a new brake does it come ready bled?
Posted : 23/01/2009 12:30 am
Depends on the make, and not even that. Both a friend and I recently bought XT discs from merlin. His came bled, I had to assemble, then bleed, then rebleed, then eventually take them humbly to the LBS to get to work as the pistons wouldn't unstick. Ask before you buy...
Posted : 23/01/2009 1:50 am
Be prepared to bleed them anyway. I have never had to bleed Hope brakes for spongyness reasons, but often had to re-route hoses so needed to bleed.
The last bike I put brakes on I used OEM XTs and they had more air in them than fluid. After bleeding they were awesome though.
If they are Avid or Hayes you'll need a bleed kit (they need threaded fittings), most others you can do with a length of tubing and a Fairy liquid bottle.
Posted : 23/01/2009 8:44 am
