Are all 142mm x 12m...
[Closed] Are all 142mm x 12mm hubs equal?
Bought a new frame that has a direct post brake mount for a 180mm rotor. When i put my wheel (with rotor) in the frame the caliper is 2-3mm away from being centred.
Because my caliper cannot be moved closer to the rotor (max adjusted towards the rotor) it appears i need to space my rotor from the hub by 2mm.
I thought the 142mm axle was a standard??
Does anyone have any measured dimensions of their hubs from edge of axle to the rotor surface mount on their hub for my comparison pleasE?
Posted : 23/11/2016 2:59 pm
Within tolerances it should all fit. It could be that the mount has been welded in the wrong place though. What frame is it?
Posted : 23/11/2016 3:01 pm
Its is. That's the axle though, no one said nothing about cassette or rotor position 😆
Hope sell rotor spacers, funnily enough because they are usually the furthest away from a common location.
Posted : 23/11/2016 3:04 pm
So is rotor shimming common practice for a lot of people??
I've tried searching on google briefly for hub dimsneions that show the distance from the edge of axle to the rotor position but am having no luck.
i just want to see if my industry nine hub dimension is different from other peoples!
Posted : 23/11/2016 3:23 pm
There is a standard, no one follows it. Shimming the rotor is more common now frames are coming with integrated post mounts rather than adaptors. Most hubs and calipers set-ups fall within the adjustment range, some combinations dont.
Posted : 23/11/2016 3:42 pm
 cp
As already mentioned, the 142 axle is nothing in itself to do with disc rotor mounting face dimensions.
But there is huge variation in hub manufacturers on disc mount face relative to dropout adaptor face, in frame manufacturers position of the post mount holes and also disc caliper manufacturers have their variations on where they put the mounting holes relative to the theoretical disc position. That's three lots of completely independent sources which all stack up.
Some frame/hubs/calipers are fine, others are out of fit. For ref. the hope disc spacers are good and available in a range of thicknesses.
Posted : 23/11/2016 3:52 pm
Syntace have some very nice [url= https://www.syntace.com/index.cfm?pid=3&pk=757 ]stainless disc shims[/url]...
Posted : 23/11/2016 3:54 pm
Syntace have some very nice stainless disc shims...
I have some of those and they are good for getting 2 different hubs to the same alignment, but not cheap. £2 will get a hope 1 or 2mm spacer which is all you need if you only have one wheelset and just need to get the rotor into caliper adjustment range.
Posted : 23/11/2016 4:14 pm
Thanks all, hadn't realised that mounts were all over the shop. I'll look at shimming up
Posted : 23/11/2016 4:51 pm
dizcostix - Member
They shouldn't be. What frame is it?
Posted : 23/11/2016 5:39 pm
