Arch ex - can you u...
[Closed] Arch ex - can you use 21mm stans tape?
I think you are meant to use 25mm, but can you get away with 21mm? (as I already have a roll)
Thanks
Posted : 13/06/2013 9:01 am
Yes it'll be fine
I have rims that have been taped with 21 & 25mm
Posted : 13/06/2013 10:12 am
cheers frankers
assume you are running tubeless?
thanks
Posted : 13/06/2013 10:54 am
I've done this before with Crests because I bought the wrong tape. I just trimmed the edges with a Stanley knife, where the rim base meets the wall. It worked.
Using the right sized tape is easier though.
Posted : 13/06/2013 11:02 am
Yes running tubeless
Posted : 13/06/2013 12:03 pm
Mattg - I'd have to glue some on, not trim off! But looks as though 21mm will work in an arch so all good
Posted : 13/06/2013 12:05 pm
Charlie, Arch Ex and Crest are both 21mm internal width, the 21mm tape is best. http://www.notubes.com/ZTR-Rims-C18.aspx
I was wrong about the trimming, hadn't looked up the numbers, I've used 25mm tape on Crests in the past.
Posted : 13/06/2013 12:46 pm
