Anywhere with M8 Fo...
[Closed] Anywhere with M8 Fox Bottom Nuts?
Mine has damage, so needing to replace it, but they appear to be quite rare to find, anyone know, or have spares of the M8 nut that fits on the air shaft at the bottom of the Float 34s?
Posted : 30/04/2020 2:36 pm
https://www.bike24.com/p2332159.html?q=fox%20nut
Edit - sorry, that's the damper shaft nut.
This one is the air nut - https://www.bike24.com/p2332159.html?menu=1000,2,121
Argh - edit - thought I had the wrong link, it's labelled as the air nut, but the pictures and diagram are the damper side.
Posted : 30/04/2020 5:41 pm
Check the part numbers on the Fox site, Silverfish have them in stock
https://www.ridefox.com/fox17/help.php?m=bike&listall=partlist
For a 2018 34mm 110-160 FLOAT NA2 Air Spring Assemblies 241-00-005
https://www.silverfish-uk.com/products/kw/nut/SPARES/Forks/24100005_Fox-Fork-Custom-Fastener-Bottom-Nut-R-Rl-RlC
Posted : 30/04/2020 5:52 pm
Message me your address and I will send you one out FOC.
Posted : 30/04/2020 6:23 pm
