Anyone With AUTOCAD...
[Closed] Anyone With AUTOCAD (or similar) able to help me out...?
 mboy
I need a quick(ish) favour...
I want to overlay the geometries of 2 bikes over each other, in order to pick out the crucial contact points. The problem I have is that not all crucual measurements are there for both bikes.
Anyone able to help me out?
Cheers in advance
Posted : 09/03/2015 11:13 pm
 Sam
Pretty sure you can do this in the free version of BikeCAD, you certainly can in the paid one. http://www.bikecad.ca/
Posted : 10/03/2015 12:37 am
Drop me a line and I'll give it a go based on what you have - email in profile.
When do you need it?
Gaz
Posted : 10/03/2015 12:38 am
 mboy
Dropped you an email speeder
Sam, just having a mess about with the free version now, but seems a bit clunky to me. Will persevere and see where I get.
Posted : 10/03/2015 1:02 am
anyone know the standard dimension used for a 29er axle height?. We've got a BB height but that's no use without a reference axle height. Why they both can't give a BB drop I have no idea???
Posted : 10/03/2015 9:23 am
 mos
Just a wild guess, but wouldn't it be 29 inches divided by 2?
Posted : 10/03/2015 9:43 am
745 +/- 5mm for 29er wheel OD.
Posted : 10/03/2015 10:02 am
Also bear in mind that the dims will only be correct if you know the fork A-C and sag used, not everyone quotes this and if they do it's not always accurate, willingly or not.
Posted : 10/03/2015 10:05 am
jameso - Member
Axle to crown is known but I've always worked on sag being ignored on geo charts and that it always represents an unladen bike? Is that not correct?
Posted : 10/03/2015 10:42 am
Some include it, some don't. It should be stated. Sagged makes more sense generally but only really useful if stated clearly, often not so its hard to compare geos to within the 10mm or so that people often want. Then there's the way some brands will be creatively inaccurate to not spell out how the bikes laid out, for various reasons eg many Asian frame companies get geos simply by using online charts from other brands, averaging a few maybe, etc.
Posted : 10/03/2015 10:49 am
many [s]Asian[/s] frame companies get geos simply by using online charts from other brands, averaging a few maybe, etc.
fixed that for you.
Posted : 10/03/2015 10:53 am
True I expect. Only ones that admit it are over there but points to them for honesty.
Posted : 10/03/2015 11:03 am
Plenty CAD software here if your still needing a hand.........
Posted : 10/03/2015 1:47 pm
