Trying to decide between a fox float or rs rev - there is limited reviews on the newer floats with a QR but most seem to suggest that the fork is too flexi without a 15mm axle - is this the case or am I being swayed by marketing/magazine hype ? Just thinking maybe rs revs would be better in standard qr size...
I used 140 vanillas with QR for two years, wouldnt say they were noticably flexy tbh. Im using Pikes now, Maxles are better but not worth paying a big premium for.
Yes, 140 Vanillas on my 5 spot - great!
Marketing and hype. My 160mm QR fork is fine (and I ride 20mm 140mm forks on another bike for comparison). I would go 20mm in the future though, more to future proof myself than anything else.
[i]Anyone using fox 140 mm forks with a standard QR ?[/i]
Yes. I'm not buying new forks and wheel(s) just cos the mags/manufacturers say I should.
Yep. 140mm Vanillas, Hope XC hub with (SHOCK! HORROR!) a Hope Ti QR through it.
It's fine.
20mm axles are noticeably stiffer, but there's nowt wrong with a QR really.
if you have a Pro II front wheel, you could always get some 9mm bolt thru converters for it, and a 9mm bolt thru QR - 'feels' better no idea if it is though
yeah got floats and talas in qr and are fine
Nope have dt Swiss 240's - thanks for replies so far
The latter.
I'm on QR/130mm forks, I have not died or failed to enjoy my riding. Like tree says tho if I was buying wheels and forks I'd go 20mm (15 seems a waste of time to me)
i think you can upgrade the 240s as well?
would make sense as dtswiss make 9mm thru axles!
Lol see my post further down !
yep u want some of these
http://www.jensonusa.com/store/product/HU309Z00-Dt+Swiss+240S+Thru+Bolt+Rws+Adaptor.aspx?sc=FRGLUK&cc=GBP
ive done it on my foxes and you notice the difference when landing jumps at awkward angles or hitting very rocky terrain etc
Had a scare with 140 qR revs, wont use qr now. Sold them at a big loss and got pikes instead
retro83 - Member
wont use qr now.
Why not?
What was the scare?
Because my wheel almost come out under heavy braking. If it had i think i would have been badly hurt. One of my mates broke his neck from a fork failure when i was younger ๐
Yep...
zochi 44's They seem to have heavily cowled dropouts and to be honest side by side comparison with a set of pikes in our household it's hard to find a tangible difference.
Sympathy for your mate. I use hex skewers, and they have never even remotely come loose.
Actually i did, and had epic fail with those too. Probably i'd done them up too tight after the first incident. Under cornering the end of the bolt pinged off!
Reviewers probably overstate the difference a bit, but if you can afford the 15mm or 20mm axle versions then I'd say you'd appreciate the benefits.
If not, you'll still have fun with a QR fork.
i use a max 140mm fox talas and it's fine with QR. i can notice the flex at 140 compared to 100mm, but it's not that bad and isn't enough to ping me off line/off the bike. never had a QR come loose (Hope stainless). I also use a 203mm front disc... never tried a Maxle or similar.
Had am 09 Talas with 9mmQR and it was fine.
Now have a 10 Float with 15mm and it's noticeably stiffer but as I say, the 9mm on the Talas was fine.
Yeah I have 09 Fox 140mm forks on my Zesty, was planning to swap in maxle- lite 09 Revs I also had along with converted 20mm wheel but I've never noticed it being flexy so have left the Revs on another bike and converted the 20mm wheel back to QR on the Zesty.
Why would it be "wrong/bad"? You'll be fine...
I wouldn't use a QR anymore, but it's not travel related.
Standard QR on mountain bikes = FAIL (road bike technology)
what is your rush about getting the wheel out anyway?
Why wouldn't you want more direct steering and a stiffer front end?
when there was no option , fair enough, but get with the times\technology people
(if you don't ride fast enough to feel the bike flex, and like getting your wheels out quick, ignore the above)
Got some magura menja's, a whole other world of stiffness compared to other QR forks ๐
And no chance of the axel poping out,
a) shimano XTR QR's
b) the cowels are mahoooooooosive, the end of the QR practicaly has to come off to get the wheel out!
Would go bolt through next time though. Had a set of 130mm Z1's and they were brutally stiff. But about 3lb heavier so they should be!
I've got some '07 TALAS with QR, using with a Hope Bulb and hope Ti QR skewer, don't find them to be overly flexy, but I haven't tried 15mm ones for comparison.
nice sweeping statement ....
Somepeople just get on with riding regardless of kit ....
id have no qualms riding 140mm QR forks - if your riding slow enough to have time to think about the flex then get your finger out and get on some skills days ๐
im comparing my experiances on forks from 07 sids , 09 sids , reba 29ers , monster TS (you wont find a stiffer fork im sure of it ) , 888s , boxxers x, Xvert DCs and all sorts of other old forks - i guess its a being used to the old stuff - RST hi 5s and marzocchi z1 bams (those were ace but were flexy i dont care what anyone says - at the same time it never hindered my riding at all)
nice balanced view then
trail_rat - I bent the arch on a pair of original orange z1's - would I have done it if they were bolt through? more than likely not.
A big list of old forks proves nothing, other than technology has moved forward, as has the speed and capability of mountain bikes - Do motorcross bikes have a slim quick release mechanism?
Are you happy with a system that in some peoples opinion combined with disc brakes can undo?
Well why use standard QR then?
I can't see the sense in it when there are alternatives.
Lets be honest, another couple of years or so (we already have 2 non-QR standards - 15mm, 20mm) you won't be able to get standard QR wheels or forks anyway. Then where will you be? Riding a hybrid on a tow path, most probably
i bent my monster Ts - if you try hard enough you will break anything .... them being 20mm or not wouldnt have mattered .... i snapped the hi5s as well -20mm wouldnt have helped there either ....
its great there is an option but not all of us NEED 20mm or 15mm .... Im from a downhill background - there 20mm/15mm has a market ... i now race xc and 24s to fairly high pace and wouldnt use anything but QR for that .....
Now if i was specing an all mountain bike for my self it would have QR forks because i dont believe all the hype about disks ripping wheels out - frankly IMHO it cant happen unless your wheel has come loose due to lawyers lips ...if a fork hasnt got them i wouldnt ride the bike period .... i do know some xc racers file them off - this would give rise for the wheel to come out under braking im sure
so, all things being equal, given the choice between 15mm, 20mm and standard QR, you would chose QR? why?
because you can get your wheels out quicker? Because its cheaper? Lighter?
please explain as I really don't understand a conscious decision to do that, and more than that, advising other people to take that route (who might not be racing xc or 24s)
lets me put the bike in the van easier if i wish to sleep on the left side of the van
lol - i don't race 24s or xc but I'm not exactly a big hitter..
Maxles are quicker to remove than QR skewers, for my clumsy fingers at least.
so no good reason then.
cheers.
chakaping - MemberMaxles are quicker to remove than QR skewers, for my clumsy fingers at least.
Have to agree, & no silly making sure the wheel is centred either. Its fine on my road & CX bike but with my weight & rocky stuff I'm much happier with Maxle kit.
I have qr hubs. Good deals on qr forks ATM. Shimano skewers seem as safe as houses .
OK, this is slightly unhelpful as my comparison is QR and 20mm Revelations, not Foxes. But, it's a pretty good comparison. I used to have QR 130mm revelations on my Soul, which were briefly replaced with Maxle 140mm revelations. Same wheel, frame, etc, in fact the only components that changed were the fork, and the adaptors in the wheel.
Yep, the maxle one was stiffer. The difference is there if you think about it... But once on the trail, I just didn't think about it, both forks got on with the job fine. People said "Oh, you'll never go back to QR"- after a couple of months, I did, and it's absolutely fine. The difference just isn't big enough to get worked up about, and in the final analysis I don't think it make any actual difference to my riding.
The big bike has a maxle in it, since the newer revelations don't carry much weight penalty for it there didn't seem much reason not to, but I'd be happy enough with QR in that I'm sure.
thanks northwind - thats helpful
oh and all others too !
I have both 140 RQ Float RLC's and Rev 20mm Maxle lite. The Foxes seems fine to me and never seem that flexy at all. However I've not been able to test the revs since I have no cranks or brakes on my Mmmbop to test them out ๐
Well I don't really know dasnut and what it considers all mountain, but form where I see it (the bottom of very rocky one), never ever had any problem with QR (I use shimano mind). Unless you are in the top 20 of the local enduro races (maybe dasnut is but I very much doubt) you'll be just fine. A bit of flex isn't always a bad thing.
But hey what would i know about riding bikes on moutain ...
EDIT Actually although I have a van 32 in 140 mm, I had a go a few time on my LBS's owner's meta (so same bike as me) who has a Talas 2010 in 150 and 15 mm axle. I can't remember being surprise by the flex/lack of it.
What thisisnotaspoon said. I got some menjas a month ago and am *very* impressed by them.
LOLling at:
Yeah, so forget your gears too. Ridiculous.
