Anyone used a Hope ...
[Closed] Anyone used a Hope RX4 caliper
I'm looking to buy a GRX groupset, but you can't buy it bundled with postmount calipers. I was thinking of using hopes RX4 calipers and wondered if anyone had any experience of using them.
Thanks in advance.
Posted : 31/01/2020 5:02 pm
Yup, they're great. I've had both Shimano and the RX4 and the RX4 is def more powerful.
Posted : 31/01/2020 5:03 pm
Yes, I have them with R7000 stis. Brilliant calipers - very powerful and seem much less prone to squeal than shimano (if my clubmates' bikes are anything to go by).
Posted : 31/01/2020 5:54 pm
I have some.
Better than Shimano and easier to set to avoid rubbing.
Not much in it power wise.
Bleeding the front was easy, the rear was a pain.
Rear caliper failed at the pad bolt. Salt corrosion possibly a factor.
Posted : 31/01/2020 6:09 pm
Where did you get them from?
There are a few places that only seem to have 1 in stock.
Posted : 31/01/2020 6:13 pm
I'm have 2 sets of post mount Shimano version calipers on 2 ebikes. Very good so far.
One thing to be aware of is I believe the Sram version uses odd pads, whereas the Shimano is normal E4 pads.
Posted : 31/01/2020 8:00 pm
Fitting is a little bit of a fiddle as the barbed hose adapter is for a slightly bigger diameter ย hose than the shimano bh90 but it works fine.
Posted : 31/01/2020 10:29 pm
