I was hoping someone would reply to this, I would like to know as well.
I was just about to try those but went with Revolution ones instead as they're cheaper. Look decent enough though.
Are these the ones?
[url= http://www.edinburghbicycle.com/ebwPNLqrymode.a4p?f_ProductID=10854&f_SupersetQRY=C207&f_SortOrderID=1&f_bct=c003154c003227c003229 ]Grips[/url]
Are the lock on bolts a good size? Some of these types of grips have quite small bolts.
looks ok
for putting on the top of a walking stick maybe? 😕
don't like the look of that big bulge in the middle of the palm.
don't like much tho'
I tried the revolution ones - there OK, but I found that the bar-end was too flat when the grips were comfy. OR what I mean is when the hand grip is flatish to support the hand, the barend section could do to point up a bit more.
Now I use Ergon as the bar end is adjustable.
Yeah, they seem to fit me quite nicely but I can see exactly what you mean, being able to rotate the barends could be a big advantage.
just received some and initial impressions are that they are pretty heavy (around 185 grammes each side !!)
