Hello , i need some advice...
I have a shimano HT BB, tools i have, screwdriver, hammmer, vice, will it work!?
Do i just knock the old bearing out, and press in the new one..?
Thanxxxxxxxxxxxxxxxxxxx
what's the point when a set of Tiagra HTII cups costs £3ish from rosebikes
To get some better ones !
Oh, and do point me out, where to get some good ones too 😉
I think the shimano bearings are a non standard size. Its easy to remove the bearings - drop the cups in boiling water and they ten will come out easily with a few taps
how good do you reckon tiny steel balls in cups with a slither of grease and a couple of rubber seals can get?
GW - Memberwhat's the point when a set of Tiagra HTII cups costs £3ish from rosebikes
Getting mtb cranks to fit in a roadie BB cups is huge faff too. I would spend a bit more to have ones that fitted proper. What ever happened to the guy on the old forum who had the enormous rage/flounce about his 'bargain' acros ceramic roadie-fit BB?
About £6 for deore and £13 for XT and £16 for xtr from rosebikes.
Superstar cups take standard bearings.
Not a fan of the enduroforkseals design without the tophats. Seized bearing=scored axle=new cranks
How come people worry about the seized bearing/scored axle thing on a bottom bracket but not when exactly the same system is turned on it's side and asked to move less for the forks?
Steerer touches the crown race and the collet, not the bearings. And headtubes dont fill with water as much as BB shells.
if you'd find simply re-using your mtb BB spacers and plastic sleeve to be huge and faffy I'd expect you to get your LBS to fit the cups for you anyway. the actual cups are exactly the same 😛Getting mtb cranks to fit in a roadie BB cups is huge faff too.
maybe onzadog is thinking of sunline's retarded attempt at a headset from a few years back 😉
Thanks for the tip GW, every day's a school day.
AFAIK Uncle shimano always advised us never to 'cross the streams' so to speak. 😉 But then they would I suppose!
I certainly won't be bothering with enduro bearing replacements any more (incidentally, mine have been ace and very well sealed) whilst whole shimano units are so cheap.
Surely you have to add on p&p to Rose Bikes price. I did what Jeb wants to do, today. Two bits of wood screwed to bench with bits cut out to support the cup, then wack out old bearing. Pushed new bearing in with vice. Worked really well. Got bearings from RS Components. HTH.
Yes done it a few times.
[url= http://www.enduroforkseals.com/sitebuildercontent/sitebuilderfiles/hollowtech2a.pdf ]done with these[/url]
And also some cheap ones off ebay
what's the point
ERR because you can. 🙄
