Anyone running a Fo...
[Closed] Anyone running a Fox 36 29er fork at 130-140mm
Anyone running a Fox 36 29er fork at 130-140mm?
Posted : 28/02/2018 7:17 pm
I have a 29er version and the travel I believe can be reduced to 120mm internally. Fox said no parts were needed and they can make the change when the forks are serviced in a week or 2.
Posted : 28/02/2018 10:23 pm
Hi
Ive ย got a 36 Talas (150-135)
The lower travel can be adjusted using spacers.
I run it at the lower setting most of the time and just go to full travel for big descents.
Not sure that helps?
Steve
Posted : 28/02/2018 11:32 pm
You'll not be able to run a 2018 36 at that travel.. possibly 140 but certainly not 130mm yet as afaik Fox havent made that lower airshaft length yet.
2016/2017 you can add alloy spacers to the air shaft rather than having to replace teh lower shaft
Posted : 01/03/2018 12:41 am
no, 150mm for me, new airshaft required on 2018.ย ย  anything 140mm or below I don't think you would see the benefit of aย beefier stanchionsย i.e comparing fox 34 to 36,
Posted : 01/03/2018 8:35 am
