Anyone own a 7.875 ...
[Closed] Anyone own a 7.875 x 2.25" / 7.875 x 2.00" Fox RP23? Stroke length question.....
Does anyone own a Fox RP23 in either of the above two eye to eye / stroke lengths? I think in millimeters the measurements are 200X57 / 200x51.
I've just picked up an OEM version to upgrade my Specialized Camber. The required eye to eye / stroke is 200x51.
The eye to eye is fine but the exposed shaft measures 57mm on my new one. When I install it on my bike, let all the air out of the shock and fully compress it the seal to o-ring measures travel of approximately 48/49mm travel.
Is this normal? Do Fox make the 7.875 x 2.25" / 200X57 then put a travel limiter / spacer inside to convert it to a 7.875 x 2.00" / 200x51? Or do I have the wrong stroke length? ๐Ÿ˜•
Posted : 05/03/2014 2:45 pm
Cheeky bump for the evening crowd. ๐Ÿ˜€
Posted : 05/03/2014 9:49 pm
Yes it's normal, they're the same shock, the 51mm stroke version has a spacer on the shaft inside the body to limit the travel,
Posted : 05/03/2014 10:06 pm
Just measured mine on my 26er camber. Bought as a 200x51, measures approx 57mm from seal to shaft end.
Posted : 05/03/2014 10:12 pm
Cheers for the information. I thought this might be the case.
Posted : 05/03/2014 10:52 pm
