Anyone Not botherin...
[Closed] Anyone Not bothering to carry a spare innertube ?
Hi, I run tubeless (MTB) and have recently decided to cut down on gear taken on rides and ditch the backpack for most rides. Having already decided to not carry a pump for the majority of my riding (exception being long day rides away from much civilisation) and carrying 4 20g co2 instead (on the bike) I was wondering about not bothering with a spare Tube and carrying a Tubeless repair tool such as a Dynaplug.
I appreciate there will be opinions on this and I am fully aware of the pros and cons so really just wanted to hear from other riders that are doing the same and if they have always managed to sort out a puncture. Given the seeming ease of use and reliability of a Dynaplug tool and a well maintained tyre sealant setup I just wonder if an innertube and levers would ever be used anymore...
Much appreciate any feedback.
Posted : 05/08/2019 4:13 pm
 rone
Haven't carried one for years.
Catches me out maybe once a year.
Carry loctite glue for a bit of redundancy.
The pump I've come full circle with as co2 often fails and then you are stuck.
Posted : 05/08/2019 4:21 pm
I've put a hole in my tyre bigger than my worm can fill, needing a tube. I've now got a frame pump, Samurai plugs, 1 CO2, and a tube. Often the fix is a plug, plus just a quick pump up, but I always have the tube to get home with.
Posted : 05/08/2019 4:22 pm
In the last 3 years of running tubeless, I've needed an inner tube twice. Both times I got punctures too big for sealant to seal. I find CO2 cartridges too unreliable and they're not environmentally friendly, so I always carry a pump even at that low frequency of needing one. Sometimes, even when sealant does fix the puncture, quite a lot of air can have escaped which requires a top-up to continue riding.
Combined with the fact that sod's law dictates that punctures always occur at the furthest distance from home or the car, to answer your question I always carry a tube and pump. It's not worth the weight saving versus the inconvenience of when bad things do happen.
I now also carry one of those "bacon and needle" kits to be sure I don't get stranded in the middle of nowhere. If I never use it, it will still have been worth the peace of mind.
Posted : 05/08/2019 4:37 pm
[rone: Haven’t carried one for years. Catches me out maybe once a year. Carry loctite glue for a bit of redundancy. The pump I’ve come full circle with as co2 often fails and then you are stuck.]
Thanks for the feedback, I decided to ditch the pump as after doing some testing with my mini pump it took around 500 strokes just to get to 22psi (maybe I need a better pump) but I figure 4 cartridges has a fair allowance for failures and cock ups (or a run of punctures) - I just felt perhaps in this modern era of tubeless with sealant and funky dynaplugs do I still really need a tube for most rides..
Posted : 05/08/2019 4:45 pm
Interested as to why people are finding Co2 so unreliable - its always worked for me. Maybe its the type/brand of inflator head that's the problem ?
Posted : 05/08/2019 4:49 pm
is for cartridges and the head required any lighter than a decent pump?
Posted : 05/08/2019 4:50 pm
In five years of running tubeless I've only needed a tube twice. Once was when I dinged a rim on a water bar and there was no way the tyre would seal. The other time was a minor hole and for some reason the sealant wouldn't seal the hole and it was way too small for an anchovy.
I do carry a tube but I'm often on rides several hours from anywhere and it's just force of habit. I even carry one on the fat bike but then doing things like racing in the arctic is a bit specialised and getting "rescued": "Hi, I've a mechanical can you pick me up please?" "Sure, that'll be 200 Euros. Cash only" I kid you not.
Posted : 05/08/2019 4:53 pm
for a quick local ride I take a small pack with inflator, tube, mini tool a spare cable and chainlink. The inflator got me home on friday after a small slow puncture that didnt seal.
Anything longer or further a field all the above + another tube, pads and a pump (lezyne mini track pump FTW)
no, just smaller and quicker if it works
Posted : 05/08/2019 4:54 pm
I never carry tubes and I’m not tubeless. Not had a puncture in years
Posted : 05/08/2019 4:58 pm
Not so much weight, but the cartridges are much smaller than a decent pump.
Only using 28c tyres but I carry a tube, CO2 and head plus a very short 15mm spanner (track nuts) in a tiny little bag that goes in back of jersey pocket. I can't do that with a pump.
Can’t believe you wouldn’t carry a tube. I’ve been tubeless for years and always do. Doesn’t take much of a slash for sealant to fail. Tube in, carryon riding. That said I can’t recall this happening but as soon as I ditch a spare tube, it’s guaranteed to happen!
Posted : 05/08/2019 4:59 pm
Tyres/wheels I use for local xc rides on the smuggler are full of thorns, inner tube would be useless. Plenty of sealant in there, 2/3 co2 canisters and a dynaplug kit.
Most places we ride are at most 5 miles from the car. Only take an inntertube on big days out (e.g. Peaks) and will have a pump as well.
Posted : 05/08/2019 5:03 pm
It depends on the ride. If I’m going KMs from civilisation I’ll take the kitchen sink, but if I reckon it will take me less than half an hour to hoike the bike back to my house/a mate’s house/my car/a bike shop then I don’t bother.
Most of my rides are the second case, so I don’t usually carry one.
Posted : 05/08/2019 5:05 pm
CO2 cartridge and inflated in steerer tube, mini pump under bottle cage, tube in tube tarp in a space by seat tube created by tube layout and Samarai tubeless plug kit in bar ends.
Posted : 05/08/2019 5:08 pm
I think this is probably one of the things where you need to think about consequences. A year or so back I was up the top of Jacob's Ladder an hour or so before nightfall and flatted a tubeless rear tyre. Didn't have a tube as I'd been juggling wheel and tube sizes and somehow hadn't put either in.
Fortunately I found an anchovy repair thing in my pack and it sealed the hole. If it hadn't I'd have had a couple of hours push in the dark to get home. I was okay, but if the repair hadn't worked, that would have been it in a slightly tiresome way.
If I were riding 20 minutes from my front door, no big deal, but for anything further or with a risk of benightment, I like the extra reassurance I can get home - a tube and a gel wrapper or tyre boot can fix stuff that a repair kit can't. I don't really care about a few hundred extra grammes in my pack.
I once met a guy on a road bike who didn't carry a pump or tube - long story but the short of it was that the two times he'd flatted, he'd flagged down a passing car and cadged a lift home. I'd rather be a little less dependent on the kindness of strangers. YMMV,
Posted : 05/08/2019 5:10 pm
For shorter, local rides: pump clipped to downtube next to bottle cage. Toolkit (including anchovies and applicator) in Jerry Can bag* - phone, debit card and cash and minimal FAK go in there as well.
For multi-day rides I'll also shove in a tyre boot (piece of old toothpaste tube) and a sewing kit for bigger slashes.
* Seems to be the name for a top tube bag that sits in the seat tube - top tube junction.
Depends on the ride. Short ones where I use a bus bag I do t take a tube - but I’m rarely further than 30 mins walk to the car. I have a mini pump and a tubeless repair kit in that bag just in case. I’ve been tubeless for 2 and a bit years and my tubeless kit is still unopened at present.
Longer rides at bigger places I have a back pack with a camelbak in it for water so I may as well carry a tube as it’s not that heavy and gives me a backup. Will also have a puncture repair kit in that case and a mini tool with pliers on to undo the tubeless valve nut in case I need to pop a tube in.
Posted : 05/08/2019 5:20 pm
Carry a tubolito tube. Light enough that it's no hassle to have it with me
Posted : 05/08/2019 5:21 pm
 rone
Interested as to why people are finding Co2 so unreliable – its always worked for me. Maybe its the type/brand of inflator head that’s the problem ?
Well for one, it's a finite opportunity limited by the number of cartridges you carry. So, if your tyre fails to inflate you've only got so many goes
Second I'm on my third co2 inflator, they're spring loaded and have failed me a couple of times. Enough to be annoying. That said I might try a lezyne one. Their pumps have been great.
It's all risk assessment. Minimise your kit for sure, but then accept what could go wrong and how you will fix it.
Posted : 05/08/2019 5:22 pm
 kcr
Carrying a pump and a tube does not inconvenience me, so I'm happy to have them as insurance for a situation that is very rare, but also very inconvenient if it happens.
Posted : 05/08/2019 5:32 pm
Depends on the ride and the bike.
Fat bike I don't bother as trying to inflate it with a tube would be such a monumental faff, the tyre carcass if full of thorns and tubes aren't light. I do still take a decent pump and anchovies. Absolute worst case there's always the old bodge of filling the wheel with grass.
For anything else, a tube weighs 150g and lives in the saddle bag.
Might stop bothering as tubes seem to degrade and split before they get used! Not sure if it's residual chain oil in the saddlebag, or light, or bike cleaner or what that does it, but they all crack and split eventually along the folds.
Posted : 05/08/2019 5:38 pm
Almost always. Even my local rides can have 2-3 hours walk from help should things go awry.
Around a trail centre, maybe not worthwhile.
Well for one, it’s a finite opportunity limited by the number of cartridges you carry. So, if your tyre fails to inflate you’ve only got so many goes
A given..
Second I’m on my third co2 inflator, they’re spring loaded and have failed me a couple of times. Enough to be annoying. That said I might try a lezyne one. Their pumps have been great.
Oddly I've had a couple of pumps that have let me down for various unknown reasons - my Co2 did work!
It’s all risk assessment. Minimise your kit for sure, but then accept what could go wrong and how you will fix it.
Yep it is, its how far do you go with carrying spares and tools for fixing problems that you hope will never happen, and trying to grade the likelihood of those 'things' happening and the consequences. If your not careful you can end up carrying a ton of stuff... its a balance that I guess is up to the individual to strike.
Posted : 05/08/2019 5:45 pm
I'm happy for people who don't carry basic spares, but please don't try to bum them off me when things go wrong.
Posted : 05/08/2019 5:46 pm
Thanks for all the responses.
I guess a flat tyre is something that you cant continue to ride on. Lots of other things can be cobbled up to allow you to ride even if its in a slightly awkward fashion - as long as you have suitable tools and parts that is! Even if thats ending up with a single speed bike with a shortened chain because the derailleur got smashed (or other similar situations)
I think your responses have helped - I will continue to carry a tube and still get a Dynaplug Racer (or Similar) as that could well help effect a quick repair without resorting to the faf of inserting a tube in the mess of sealant and probably mud.
Still not sure about a pump, given the amount of pumping required but I guess for the weight I may as well keep it on the bike as extra insurance.
Thanks to everyone who commented.
Posted : 05/08/2019 6:03 pm
Carry a tubolito tube. Light enough that it’s no hassle to have it with me.
@honourablegeorge - of the two people I know who've had to use a tubolito both have had problems. One of those two was me! In my case the tubolito would slowly deflate over a period of about an hour to ninety minutes.
I've posted this link before and it's aimed at road cyclists but his argument is that, to paraphrase an ex-prime minister: "Tubeless means tubeless" - https://thecycleclinic.co.uk/blogs/news/living-with-tubeless-tyres (I just wish he'd worn a light coloured jumper!)
Posted : 05/08/2019 6:07 pm
i know co2 is cool.. but why bother if you need a pump as a fallback? just carry a pump
note: this only applies to non-pro-racers!
if you're a pro-racer do co2, otherwise get over it 😮
Posted : 05/08/2019 6:14 pm
I’ve posted this link before and it’s aimed at road cyclists but his argument is that, to paraphrase an ex-prime minister: “Tubeless means tubeless” –> https://thecycleclinic.co.uk/blogs/news/living-with-tubeless-tyres
Interesting link, perhaps we do need to adjust our approach - perhaps innertubes are a thing of the past......
Oh what to do !
Posted : 05/08/2019 6:15 pm
I'm sure it'll come back to bite me, but I don't carry anything. I don't even have a bottle cage. Does suck when you get a flat, but it's only happened a couple of times.
Posted : 05/08/2019 6:18 pm
I know BUT maybe its because a mini pump requires a LOT (and I mean a LOT) of pump strokes to inflate a MTB tyre , Co2 is quick and easy - but Co2 is a one shot only so makes you feel a little vulnerable if you use all your cartridges....
Posted : 05/08/2019 6:19 pm
and i run plus... and i've done it with a high volume pump. not so painful 🙂
carry the appropriate pump. i've never had a flat since going tubeless but still carry the right tube for the wheelset (plus or 29) and either the mini pump (summer -> using 5L hotlaps) or otherwise using a camelbak.
Posted : 05/08/2019 6:26 pm
I've messed about with tubeless since before it was a product you could buy and DIY was king, circa. 2002. By 2005/6 the system was sufficiently refined and products coming online (Stans gen 1 rims and rim strips are the most notable), that you could make a reliable seal and resist burping. Since then tubeless has evolved to become more and more reliable and I dropped carrying a tube in 2009.
There's simply no point. I found that by the time I actually needed a tube, the tyre was so riddled with thorns that the tube that went in was usually punctured within a few Kms, even if I was careful to look for thorns before loading it up. Much better to use anchovies to plug the hole you know about and carry a little tube of spare fluid.
Since then, I've used a tube twice that I can remember. Bother were epic sidewall cuts. Even most sidewall cuts can be dealt with with 2/3/4 pugs stuffed in the hole.
Posted : 05/08/2019 7:28 pm
 nofx
I use slime in the inner tubes. I'm not a weight weeny, I'm carrying 2 stone of extra fat, so a bottle of slime makes no odds
Posted : 05/08/2019 7:44 pm
The one time I don't carry one is the time I will need one, so yes I still take the one I bought when I went tubeless on my first 650b 3 and half years ago.
Posted : 05/08/2019 7:49 pm
I've needed a tube once in about 10 years of tubeless. I ran over some glass, it sealed, ran over some more glass and it didn't.
However I still carry two tubes and even a puncture kit on longer rides. I am considering ditching them for short local rides.
Posted : 05/08/2019 7:55 pm
Been running tubeless for 8+ years now, and though I've always carried a tube, I've not had to use one personally...yet.
BUT, I have had to give a tube on more than one occasion to a riding friend that has had a catastrophic tubeless failure, and not been carrying a tube. So don't be that person!
Had to use anchovies on probably 8/9 occasions and those plus a pump have always got me home.
So on balance I could ditch the tube, but might regret it. But I'll always carry anchovies and a pump.
I Don't like C02 for a few reasons.....it sometimes doesn't play well with sealant; it has a finite number of uses (what happens if you need to top your tyre up 3 or 4 times?); it's environmentally wasteful due to materials used in the canisters, etc.
Posted : 05/08/2019 8:01 pm
and i run plus… and i’ve done it with a high volume pump. not so painful 🙂
Can I ask what pump you use? always good to get a recommendation. Maybe my pump is inadequate 🙂
Posted : 05/08/2019 8:06 pm
The last 2 times I tried to put a tube in I pinched in putting it in so it was useless. Very annoying thankfully that's 2 flats in about 3 years
Posted : 05/08/2019 8:12 pm
For the fat bike I use a Topeak Mountain Morph - gone from flat (the hole had sealed by the time I came to a stop) to fully inflated in less than two minutes, maybe 100 strokes - ooh err missus! Fatbike.com did a group test and the Lezyne HV Micro floor Drive came out best - https://fat-bike.com/2015/05/trail-pump-shootout/ .
On the FS and HT I've a Topeak Mountain DA - https://www.topeak.com/global/en/products/mini-pumps/1082-mountain-da
Posted : 05/08/2019 8:18 pm
Poor you. You must be running tyre pressures ridiculously high or average speeds over the fun stuff depressingly slow.
Posted : 05/08/2019 8:27 pm
I too have lately started taking less kit on rides however I'd always take a pump and tube out at minimum in a hip bag. Over the past few years I've probably given away more tibes to fellow cyclists than I've used myself.
Posted : 05/08/2019 9:03 pm
Always take a tube, two CO2 and a nano flate. They’ve never let me down. For epic must get home, I have a frame mounted mountain morph and carry two tubes and some patches too
Had two tubeless fail on the road needing tubes in the past two years. One was a very fragile Corsa Speed. The other a robust G One Speed
Posted : 05/08/2019 10:17 pm
I take 3xC02 and a tube and a puncture kit. I run tubes though.
Posted : 05/08/2019 10:25 pm
Dunno when the tube left my commuting pack, but haven’t carried one I reckon for a few years. Got stranded once, but that was because my pump broke.
One mtb puncture in memory and that was fixed by Dyna-plug and a quick pump.
Not sure why it upsets Trailrider Jim that someone else doesn’t get punctures. 😂
Posted : 05/08/2019 10:31 pm
 rone
Try a lezyne. One of the higher volume ones.
Posted : 06/08/2019 5:13 am
Never carry a tube or a pump. I've done the walk of shame twice in the last 20 years.
Posted : 06/08/2019 7:09 am
I have a dynaplug its excellent, great for using where a ride isn't too far from the car, so winch and descent spots. I think that if it happened, the dynaplug would get me back to the car where I leave the tube, pump, etc. I haven't needed to use the dynaplug myself, but I have been generous enough to use it on friends punctures and its worked fine each time.
Bigger rides, yes still carry a tube and a pump which does CO2 and holds a canister.
Posted : 06/08/2019 10:12 am
i have a pump, tube and dynaplug permanently in my downtube.
if im solo and i get a flat then fine. however anyone getting a flat in a group that doesnt carry a tube should be rolled into a ditch and their bike stripped for bits
Posted : 06/08/2019 10:18 am
I was going to say why would anyone do that, but yes once or twice on local rides when I'm packing light/could walk home in a disaster without too much hassle, I've taken dynaplugs and a pump only.
Posted : 06/08/2019 10:26 am
The Topeak Mountain DA (and I presume others) comes with a mounting clip that fits under your bottle cage. Fit it, clip and strap the pump in and forget about it until you need it. There's no need to consider not taking it.
I've the Sahmurai tyre plugs - the applicator replaces your bar end plug so again it's fit and forget until you need it.
That leaves the inner tube: either put in a plastic bag and tape it in to one of the angles of your frame or get a small top tube bag and mount that inside the main triangle as in the yellow bag here which gives you room for the rest of your toolkit.
Posted : 06/08/2019 10:37 am
 FOG
Not by design I have ended up with bikes with all the current wheel sizes so each bike has a pump and tube strapped to it. Ok this means having three pumps but I have been cycling a long time so have accumulated a few over the years . {whether they still work or not is another matter!]
This means I can get out quickly without searching for stuff and don't need to carry very much at all.
Somebody mentioned trail centres, why do you see people with huge packs going round?
Most trail centres have a bike shop and caff so surely the bare minimum would do?
Posted : 06/08/2019 10:42 am
I’m happy for people who don’t carry basic spares, but please don’t try to bum them off me when things go wrong.
This. I've handed out but my tyre plugs and experience/expertise for fellow tubeless riders far more than I've ever needed a tube.
Pump and tube in my backpack. Backpack on for every ride, even 1 hour pootle from home. I just dont see the point in risking it. It not like its a massive hardship to carry them.
Tubeless for 7 years and required a tube 3 times. 2 of those times would have involved a massive walk back.
Posted : 06/08/2019 10:46 am
I mostly ride with my son and/or groups of other riders these days. For safety for him and out of consideration to the others, I'll always carry enough kit so that I won't be the one scrounging tubes, or be put in a situation where my son ends up stuck somewhere remote when the weather might turn. Our bikes are (mostly) tubeless these days, even the road ones, but I've still gashed the odd tyre, or had the occasional burp that wouldn't reseal, such that I wouldn't go out without the means to fix it.
For me, this means a few CO2 carts (not used pumps for years), spare tubes (to suit the bikes we have, but at least one each), tyre boot to patch a gashed sidewall and enough tools and spares to fix basic issues. All fits in a small saddlebag, with the tubes stuffed in jersey pockets. If I'm doing a bigger or more remote offroad ride with no support available, will also carry spare tyres in rucksack.
I guess it depends on who you choose to ride with, but I don't want to be "that guy" who always scrounges bits from those who have come properly prepared. They are the ones that don't get invited out on future rides...
Posted : 06/08/2019 11:04 am
Always carry a tube, just hate getting caught out! But I'm old too, so carry more than I need...Also got a beto 2 in 1 pump and has been used on other peoples suspension. Well handy Still cheap on ebay I think.
Posted : 06/08/2019 11:12 am
I always carry a tube. I have tube, levers, CO2 & inflator and multi tool strapped to my frame; quick link under the head cap and usually carry a puncture kit with bacon strips in.
On the fatbike I carry a pump that mounts next to the bottle but I can't fit the bracket to the other bikes and still be able to clamp it to the roof rack.
Not had a puncture in a tubeless tyre yet, last punctures we've had to sort were a bust valve on the fatbike tube and a snake bite on the back of my hardtail doing the great glen way, I hadn't got around to switching to tubeless yet although it bust the tyre so definitely would have used the spare tube either way.
Posted : 06/08/2019 11:22 am
depends on the situation - a 2 hour evening group ride like I do every week, I'd much rather someone with a broken bike made their own way home, rather than take 15 minutes to repair their bike while the rest of us shiver or get bitten by mozzies depending on season.
Happened to me once, dodgy old valve with a slow leak went soft in the first 10 mins. Was happy to take myself home and reflect on my maintenance regime rather than ruin everyone else's evening.
Riding with no backpack is amazing, so much extra movement in the shoulders, and helps with heat management too. I avoid one wherever possible.
Posted : 06/08/2019 11:25 am
I’m in the “over prepared” camp. Mountain Morph, Tube (wheelsize isnt important - you can stretch a 26 to fit a 29 or stuff a 29 in a 26 to get you home). Anchovies in toolkit as well. Nearly always riding with K who has another tube plus CO2 (used to be another pump, but current pack doesn’t take a MM). Yes, there are loads of rides when the walk back to the car wouldnt be a problem but equally could end up a few hours away
Having tried many pumps the morphs are the only ones that will reliably get a tyre up without risking ripping the valve off (ive a road morph for road rides).
Always aim to be independent as you never know when you end up split up for some reason.
Strapping pumps and tubes to the bike has always seemed a bad idea to me - when i tried it on my commuter the pump was useless when i actually needed it.
"topeak turbo morph g". its the same as a mountain morph but with an additional flip out gauge
Posted : 06/08/2019 11:48 am
Road riding got me out of the rucksack habit and I find it really hard to go back now, so that I only ever take it now on days when the weather is changeable and I want to carry clothes. The problem with me is that the rucksack became a bit of a dumping ground, with spare tubes, tool kits, and other rubbish chucked in the bottom so I could just grab it and go. The problem was that I was carrying around loads of junk that I didn't really need because I couldn't be bothered to clear it out.
Like many riders, I'd stick a tenner in the rucksack for a snack, and then throw the change into the zip pocket at the back ("that'll come in useful next time"). I once emptied it and found nearly £30 in pound coins and assorted other change rattling around at the bottom that I'd been carting around for months!
I now have a small saddle bag and stick tube, snacks, waterproof and phone in my back pockets, with a bottole on the frame. That's 90% of the rides I do, wet or dry.
Posted : 06/08/2019 12:00 pm
I'm on my first bike with tubeless tyres, I carry a dynaplug tool, two tubes, patches, levers and a pump. I used to average less than a puncture a year with tubes but with the plus tyres on the current rigid bike I wanted to be able to run low pressures so moved away from tubes. I think the reason I carry so much is that as far as I can tell nothing has happened yet to tell me my tubeless set up is going to work when it needs to and I don't want to cut a ride short for the sake of carrying a bit of kit.
Posted : 06/08/2019 12:27 pm
Run tubeless, still carry a tube.
Only needed it once, at BPW.  Rear tyre was pretty old so got a snakebite and I hadn't checked the sealant so there was hardly any in.
Other than that, I've only ever used the tube on other people's bikes and never needed the tubless plugs I also carry.
I make sure the sealant it topped up and that my bike gets regualr bolt checks etc - touch wood, I dont seem to suffer the number of issues that some other people I ride with or hear about do.
I agree with BWD above - feel free to not carry whatever you like, but don't then ask others to bail you out.
I know of one guy who carries the TINIEST pump I have ever seen.  When he get's a punture (he runs tubes for some reason) I no longer offer my bigger, heavier, bulikier pump that I have carried round with me.  As long as he knows the route and we're close enough to the end or a shortcut back I don't wait for him now either.
Sound harsh, but he continues to make the choice to come out unprepared, despite his experiences.  If I kept coming out without food or drink and expected people to give me some of theirs I would expect to be told to sod off!
Posted : 06/08/2019 1:53 pm
I agree with BWD above – feel free to not carry whatever you like, but don’t then ask others to bail you out.
I know of one guy who carries the TINIEST pump I have ever seen. When he get’s a punture (he runs tubes for some reason) I no longer offer my bigger, heavier, bulikier pump that I have carried round with me. As long as he knows the route and we’re close enough to the end or a shortcut back I don’t wait for him now either.
Pump size is a bit different to not taking spares/tools at all though.
I take a tiny little thing (topeak something or other) on road rides that clips in under the bottle cage. It'll do 100psi+ but it takes a little while longer than the big pump on my commuter but I'm quite happy to use it for infrequent punctures every 600 miles or so. I either take that or CO2.
99 times out of 100 though on a clubrun someone will have a full size frame pump and lend that rather than either wait for the little pump or waste a cartridge. Evening rides are different, tools or not most people would tell the group to go on without them and they'll fix it/call the team car and meet them at the pub if there's a stop. Conversely I've given away more CO2 canisters than I've used myself on winter clubruns as really no one wants to be sood at the roadside whether group or solo, and the exchange rate of 1x 50p co2 cartridge for 1x tea and cake at the cafe makes Wonga look like a poor business model!
Posted : 06/08/2019 2:28 pm
Decision Made:
After reading all the comments and in particular the video link that 'whitestone' posted> https://thecycleclinic.co.uk/blogs/news/living-with-tubeless-tyres Especially a well maintained Tubeless setup.
To the few that have just gone on about not being sufficiently prepared just because you dont have an inner tube (yes if you go out with nothing then I would agree) but I would counter that list above is being pretty well prepared in the puncture department and that you can never be prepared for everything and maybe one day you will suffer from not having 'something' that you wish you did have, while someone who has got that 'something' on them rides off into the sunset!
Secondly to those who have commented on being a 'Weight Weenie' - its got nothing to do with weight, its about having a compact and efficient setup that allows the joy of doing most rides without a backpack of water and tools (and it is a real joy in many ways) - if you think that doesnt matter then you really should try some rides without one.
Anyway - some good comments so thanks for that, its helped me make my decision.
Posted : 06/08/2019 4:20 pm
I have ordered a Dynaplug Racer to plug the tyre if ever required & spare plugs
I will carry a spare valve core and tool
I might carry a small bottle of sealant if I can find a suitably small bottle with nozzle
I may add a small tube of flexible super glue to that
I already carry 4 Co2 on the bike
Doesn't all that counter your point of taking less stuff? That's more than a mini-pump and tube.
Posted : 06/08/2019 4:24 pm
A bit, yes.
If you still need someone else to lend you a pump that actually works in a reasonable time then it's only a bit different IMO.
I agree that at least you are self sufficient though, which is a big difference.
Each to their own though,  On current evidence I could get away with not carrying a tube, chainbreaker, tyre boot (grand name for a small bit of plastic!), self adhesive patches, tyre levers, tubeless repair kit - or for that matter my pump.  The second I do that I will need at least a couple of those things.  And I'll be a long way from home / the car.
Also agree that it's nice to ride without a pack - thankfully my frame has no bottle cage mounts and I hate being without a drink, so I always have a pack.
Posted : 06/08/2019 4:30 pm
Doesn’t all that counter your point of taking less stuff? That’s more than a mini-pump and tube.
NO
I already carry the Co2 and suggest you investigate the size of the rest of it! (the rest of it is way less than a pump and tube and if I can find a suitably small bottle it would be about the same) and as I said its as much about carrying a setup thats best suited to a modern tubeless setup, automatically assuming an inner tube is the answer may not be the right way to go.
Posted : 06/08/2019 4:35 pm
Re: bottle of sealant. Stans do a 50ml bottle that has a nozzle/spout that can be used to top up a tyre through the valve. No doubt other sealant manufacturers do something similar. I'll take one on multi-day trips but don't bother for short rides.
Spare valve core - yep. They can gunk up and I've had one break, admittedly it was about four years old. If you've a Lezyne multi-tool with chain breaker then one of the slots fits a removable valve core so you don't need another tool. I've a small tin with spare nuts and bolts in, the spare valve core goes in there.
Flexible glue: I got "Loctite Power Flex super glue" from our local handyman store. The princely sum of £3.40 for three 1g tubes.
Work out what your "ideal" repair kit is for short or local rides then you can add to it for longer or more remote outings. The shot of the blue Cotic Soul above is my wife's bike - a pump on the frame, tube and tools and repair kit in the Alpkit bag, add water bottle and she's good to go.
Here's my tool/repair kit:
tools
Packs down to about the size of a medium compact camera. The multi-tool is in a small pouch to stop it rubbing against other stuff. Pump mounted on frame.
Posted : 06/08/2019 4:44 pm
Yes thats about the size I want but I use Muc Off so need to look for a 40-50ml empty bottle (i'm sure ebay will have something)
Flexible glue: I got “Loctite Power Flex super glue”
I will look for that, thanks.
I carry two bottles (its a hardtail) a small seatpack takes multi tool and other tools and parts and any overflow goes in my Dakine waist pack. I feel pretty well prepared for most of my riding - my kit will look similar to your picture. Big remote day rides I will most likely take a backpack for more space for the stuff you should take on that sort of ride.
Posted : 06/08/2019 4:54 pm
Bacon strips, stabbing tool, tyre booth, inner tubes, mini-pump.
Have it all. Not taking any chances, since I had 6 miles walk on one of my rides.
All the stuff is more-less residing in my backpack all year round 🙂
Cheers!
I.
Posted : 06/08/2019 4:58 pm
Read my earlier post, and try not to be condescending. I carry most of that kit for the fat bike where spare tubes are heavy, bulky and a faff to inflate. I take the same setup on short rides where a walk back isn't a problem and the risk is low anyway.
For a quick evening blast or a race then plugs and a pump/co2 work perfectly well, possibly the ideal setup.
But why carry four CO2 cartridges (240g+inflator, and bulky) when a pump would do (110g or so, and clipped to the frame).
And for longer rides where reliability and being able to ride back to the start are more of a factor, carrying a pump and tube solves a lot of problems (they also make great slings if you break an arm!).
Posted : 06/08/2019 5:08 pm
I wasn't really, I could try so you could tell the difference 😉 I was answering your comment - its about the same and from what you said you didn't know that.
Comments are good for helping people make a decision, but then people make their own decisions which may well be different to yours....
Posted : 06/08/2019 5:25 pm
Before we start bickering ...
What you (generic you) take depends on where you ride and what you are used to in terms of tools and techniques. If you are happier with CO2 then use that. Prefer a pump? no problem. There's also a difference between "carry on riding" and "get me home/back to the car".
Posted : 06/08/2019 5:30 pm
Before we start bickering …
As if we would 🙂
But I did say in my 'Ive Made a decision' post that..
–I already carry 4 Co2 on the bike but am undecided about the pump
which means I am undecided on the pump front. I will most likely at least put the clip holder on the rear bottle cage and then I can carry it on some (or maybe all) rides, as it weighs next to nothing really even if its not the most efficient its still air!
Posted : 06/08/2019 5:40 pm
Way too late for that 🙂
Posted : 06/08/2019 7:08 pm
Yep, I'm sharpening up the tyre plug insertion tool for some combat action as we speak.... 🙂
Posted : 06/08/2019 7:23 pm
It's funny, I carry a tube but I will do anything I can do to fix a tubeless flat rather than give in and fit the tube. I also will never give it away since being caught out after giving my spare away.
I hate walking so carry a tube, tubeless repair kit and a couple of patches incase I miss a thorn. Quick link and suitable multitool. For a big day I'll carry a gear cable, mech hanger and a few cable ties. None of this requires a pack.
Oh, and a decent mini pup
Posted : 06/08/2019 8:35 pm
I carry as much as i can, two tubes, pump, tubeless repair kit, multitool, bike tool and so on, on a group ride it's for others as much as me, it's not as if i'm a racing whippet or really care about carrying an extra 0.5kg, i prefer wearing a backpack for back protection any way, so having it with kit in isn't much of an issue.
Posted : 06/08/2019 8:57 pm
You need a better pump.
I’m with the co2 doubters. I’m sure it’s awesome for racers but it’s an environmentally expensive affectation for regular riders. Not cheap I’m cash terms either unless you buy a kit that is never used...
Posted : 06/08/2019 9:07 pm
