Anyone had a succes...
[Closed] Anyone had a successful Shimano hollowtech BB warranty claim?
Has anyone had a successful Shimano hollowtech BB warranty claim? my SLX BB is totally knackered after 5 months use and i plan make a claim under warranty. Has anyone tried anything similar for a shimano hollowtech and what was the outcome?
I though it best to check before i poetntialy throw good money after bad posting the knackered BB off!
Posted : 23/06/2011 1:06 pm
you've got no chance.
Posted : 23/06/2011 1:12 pm
Mate, I have never had a successful warranty claim on anything off any of my bikes!
Posted : 23/06/2011 1:16 pm
What jam bo said.
Posted : 23/06/2011 1:23 pm
It's not faulty is it? You've just worn it out - it is a poor design though - even Superstar are better. But that isn't a warranty issue.
Buy Hope
Posted : 23/06/2011 1:30 pm
Wear and tear. Check in with Trading Standards to understand your rights before you waste lots of time...
Posted : 23/06/2011 1:53 pm
thanks for the advice, whilst it is good advice it only spurs me on further. Ive got a long history of suprious warranty claims and i've never been unsuccessful yet.
I dont quite know why i asked the question.
Posted : 23/06/2011 1:54 pm
 Bazz
I can't see you having a snowballs chance in hell, it'd be like trying to get the windscreen wipers warrantied on your car, they might be rubbish but they are a perishable item, and in 5 months you [u]could[/u] have done lejog 5 times for all they know.
Posted : 23/06/2011 1:58 pm
Do you mean "spurious"? As in false or fake?
Posted : 23/06/2011 1:59 pm
Well, if you compare to a similar item, say my oldest XT square taper on its third bike and over 10 years old, you could go with 'unfit for purpose'.
Posted : 23/06/2011 2:01 pm
I've had a new chain under warranty before now. With this in mind, surely they can be culpable for a defective BB?
Posted : 23/06/2011 2:08 pm
 anc
Its a £15 part its not worth your time and effort. Hope you faced your BB shell, before installing it... without that you haven't got a chance.
Posted : 23/06/2011 2:10 pm
You've had 5 months of use out of it, so what's the problem? It's an item that wears out. Do you claim when your tyres are worn as well?
I used to get a year at most out of XT square taper bottom brackets. I never understand why people always talk about how great they were.
Posted : 23/06/2011 2:11 pm
buzz-lightyear - Member
Posted : 23/06/2011 2:17 pm
Have you jetwashed it and be honest, I remember a guy complaining about a bb and after repeatededly claiming he had never used a jetwash on his bike admitted to frequently jetwashing it when we found the bb to be full of water and totally banjaxed.
Posted : 23/06/2011 2:20 pm
Its a £15 part
- I thought it was more a £37 rrp.
Can see both sides. It is a consumable part but not (imo) in the same regard as a set of pads or a tyre. A part that needs reasonable levels of stripping down to replace and comes with a year's warranty. I would think that it should be reasonable to expect a little more but we seem to accept this level of engineering.
On the other side as said above, this is a component that can be expected to be renewed after a certain number of miles and this can be significantly shortened depending on the conditions you ride in and potential misuse (use of a jet wash pointed directly at the seals or installed in an unfaced frame). How does a consumer prove this?
Posted : 23/06/2011 2:36 pm
I must be very lucky as my hollowtech BB is in its second bike, is about 4 years old and still absolutely fine. Must have done a good few thousand miles on it by now.
Posted : 23/06/2011 2:39 pm
What's this "jetwash" you mention?
Apart from the ocassional gentle ride all ive done for the last 5 months is follow the correct maintenance regime as recommended by the manufacturer.
5 months isn't a reasonable life span for a non-perishable component designed for the purpose for which it has been used.
In terms of forseeability its too remote a loss for me to have anticipated.
Expect to see a new SLX BB in the for sale forum shortly.
Posted : 23/06/2011 2:41 pm
 anc
£12.90 at rosebikes no one pays rrp :mrgreen:
Posted : 23/06/2011 2:43 pm
Depends on how often you ride your bikes, and in what condition.
My shimano BB has lasted 2yrs so far, and it's still smooth.
Posted : 23/06/2011 2:44 pm
I would have thought you will have to show that the 5 months is an unreasonably short life and that it is a design fault. IMO both are true but showing this is difficult and also that you have had a some use of the part so only a partial refund needed under SOGA
Worth a try if you like a fight. Me I have better things to do with my time
Posted : 23/06/2011 2:46 pm
+1 - Its a consumable.
And if you shop in Germany, you can get HT2 BBs for less than a tenner
Posted : 23/06/2011 2:47 pm
TandemJeremy - Member
Like?
Posted : 23/06/2011 3:09 pm
"Apart from the ocassional gentle ride all ive done for the last 5 months is follow the correct maintenance regime as recommended by the manufacturer"
Which is?
Posted : 23/06/2011 4:05 pm
Was your BB shell faced before you installed it?
Posted : 23/06/2011 4:08 pm
About a year from my experience for the XT/SLX, but that was with some serious jet washing which i've now stopped 😳
Still, at approx £12 form Rose, i'd rather pay that, than a larger whack up front for a Hope BB.
Posted : 23/06/2011 4:12 pm
Get your tyres and brake pads done at the same time 😐
Posted : 23/06/2011 8:41 pm
