Has anyone here got a Specialized Enduro Elite 650B in size small 2015/2016 model?
I'm interested to know the stand over height as measured from the ground to the lowest point of the top tube (for comparison purposes). I know the geo is available on-line but many companies measure this differently and usually (like Specialized) do not state how it is measured. Also if possible, how much it weights in the default spec. Thanks!
In default spec its pretty much 29.5lb.
How long are your legs, and why are you worried about standover?
Ok thanks. Not too bad then.
I've got about 26.5" inseam. Stand-over not a massive issue most of the time whilst riding, but can be critical in some situations I've encountered in the past - e.g. steep, narrow, exposed trails in the alps - where getting 2 feet down quickly can be important.
I can measure up my large from the ground with Tyres specced, and compare it to the small.
Although, don't get off the front of the bike if you want to stop! Get off the back, otherwise you'll get flipped down the hillside. Your feet are either on the pedals, or you're walking with your bike ๐
That'll be really helpful if you can do that. Thanks.
