Anyone got an Ellsw...
[Closed] Anyone got an Ellsworth Epiphany?
Thinking of a change from a large 2007 new shape Heckler which I find a bit short. I've a layback post & 100mm stem but I always feel I'm too far back behind the BB.
What size Epiphany do you ride, what height are you & do you rate it?
I'm 5'11", thinking of a large 19" Epiphany.
Posted : 10/03/2012 8:13 am
Anyone?
Posted : 11/03/2012 7:34 pm
One of mates had one.
Bit tall,bit steep,bit flexy.Light though.
Posted : 11/03/2012 7:35 pm
I have one, large and I'm 6'2". Fits really well. Cracking machine I think. Had a Superlight myself and they are a bit short on the top tube. The epiphany climbs really well. Mine doesn't have an RP23 on it just a standard fox float r but never needed the pro pedal function once. Feels about as light as the Superlight.
Posted : 11/03/2012 9:09 pm
at 5ft 11 you are still in a medium frame. I loved my epi, fastest 5" boingy mile muncher I've ever had.
not flexy at all but then I'm not a fat biffer
got mine to under 25lbs with 2.25 tyres and 140mm fork on it.
Posted : 11/03/2012 9:11 pm
But on a medium 17" I'd have a very long seat tube & the top tube would be the same as the Heckler.
Posted : 11/03/2012 9:14 pm
if you look at the size guide meduims good for 6ft. I'm 5ft 10 and a smidge and a medium was spot on with a 90mm stem.
try one out is probably the best bet. I'm sure freeborn will let you play on one
Posted : 11/03/2012 9:17 pm
Are you sure your first post is right? You think it is too short but also say that with a layback seatpost you are too far back from the BB...
One (to me suggests) you need a longer top tube and the other suggests you need to just get an inline post and see if that makes a difference to begin with.
Posted : 11/03/2012 9:21 pm
The size guide also suggests over 5'9" for a large Epi.
Dick, yes I understand what you mean but then I feel too cramped.
I have a Pace RC104 in a large with a 610mm TT & in line post with 100mm stem & this feels great.
Posted : 11/03/2012 9:34 pm
 nuke
May or may not be a problem depending on whether you run a dropper post. I do and, much as a like the idea of an Epiphany, the 27.2mm seatpost diameter on them is off putting (Can't find the diameter for the SST.2 but the SST.1 still had 27.2). Previously had a Truth which I did enjoy riding...lovely frame.
Posted : 11/03/2012 10:20 pm
But isn't the medium supposed to fit up to 6'1" people as well. The medium also has a 23.5" top tube which is well into large frame size dimensions. I have to say my first thought when I read you were 5'11 was that you should be riding a medium. My Superlight had Thomson inline post and 90mm stem and wasn't too bad, my epiphany has an inline post and 70mm stem and is spot on
Posted : 11/03/2012 11:15 pm
My mate built a large one up last year that,I had a lend of it for the weekend - Great bike,rear suspension works sooooo good.I'm just over 6ft & I wouldn't have wanted one any smaller as they aren't big bikes...At 5'11" I would try before you buy......
Posted : 12/03/2012 5:57 am
