Anyone got a 456 wi...
[Closed] Anyone got a 456 with shortish travel forks?
Building a cheap bike up for a mate and planning to put some Rebas on a 456 frame. Most travel I can get from them is 115mm. Is this going to make the front end too low? Suppose a standard Inbred frame would be better.
Posted : 17/02/2011 4:46 pm
I've got u-turn revs 100-130mm on my 456.. I usually ride it pretty much everywhere at 100mm.. usually because I forget to wind the travel out when I get to the top of something hairy.. there's some pretty tech descents on my local routes..
although sometimes I get to the bottom of a steep rocky section and think DOH! that would have been easier if I'd remembered..
works fine for me.. I find that at 130 it's a bit of a struggle keeping the front planted going up..
115 is about perfect on a 456 according to many folk..
Posted : 17/02/2011 4:52 pm
Girlfriend has 100mm Rebas on her 456 and likes it. That said she has only just started out but it seems alright. My bro has a 456 with 100mm Fox 32s on and he likes it.
I think I saw some 120mm Rebas on Merlin for about £320
Posted : 17/02/2011 4:56 pm
115 was pretty spot on on mine for most stuff - upped to 130 for steeper trails.
Posted : 17/02/2011 4:57 pm
Anyone put a standard 26inch carbon fork on a 456 ?
Posted : 17/02/2011 5:01 pm
define standard. Mine was fine with a 445mm one which is pretty standard nowadays.
Posted : 17/02/2011 5:04 pm
Standard 440mm O-O carbons shown here but if I was you I would go for the 29er carbon instead.
Posted : 17/02/2011 5:08 pm
I am tempted to try the 445 carbon forks with a 29er front wheel 🙂
Posted : 17/02/2011 5:15 pm
120mm Mav SC32's on mine I do not think I will go longer
Yep quite happy
Posted : 17/02/2011 6:17 pm
I've blabbed on about changing my 100mm Rebas to 120mm and never got round to it on the old 456 (probably 'cos I didn't need to) and now the new 456 has 100mm Recons on it and I was riding some pretty decent technical stuff last night on it - and it's fine. I suspect 120mm would be pretty decent too, but 4", 5", 6" - it's what it was designed for!
Posted : 17/02/2011 8:10 pm
100mm Tora's on mine, no problems
Posted : 17/02/2011 8:41 pm
Ive had a 145mm fork on my steel 456, which felt perfectly fine, but I swapped to a 120mm reba on my Ti when it arrived, and I think its better all round at 120mm. More responsive, less divey, better climbing.
Posted : 17/02/2011 9:08 pm
100mm RS Recons on mine. I'm not a fan of air suspension, so i got the coil ones. I've got a riser stem to bring the bars up a bit, but other than that it's spot on! I have run it with 140mm Pikes, but for day-to-day trail riding, 100mm is fine. Perfectly capapable, even on the trail center Black runs i've ridden it on.
[img] ?t=1271760652[/img]
Posted : 18/02/2011 8:56 am
Pike u-turns on mine. I reckon 120mm is nice for all round riding, so 115mm isn't far off.
Posted : 18/02/2011 12:29 pm
I had my 456SS with a rigid CF 26" fork (On-One) and a 29er wheel. Great!
Posted : 18/02/2011 12:33 pm
My Ti456 has 100mm SIDs on it as part of a racy build.
Much prefer it to when it had 120mm forks. Much faster steering and somehow feels less 'vague'.
Posted : 18/02/2011 12:54 pm
Mines run everythgi from some old 100mm MX-Pro's, magura menja 130mm (probably best suited) to some 150mm Z1's which were ace if a little overkill as theback end cant keep up.
Posted : 18/02/2011 1:12 pm
