Anyone gone tubeles...
[Closed] Anyone gone tubeless with schrader valves?
Experienced any problems?
Have seen you can get the valves but for some reason, my spider senses are tingling*.
*Tingling could be my 'oooohhh, get some new wheels' tingling or cat aids, it's just so darn hard to tell.
Posted : 30/01/2016 9:37 am
Did it with some Joe's rim strips a while back, worked fine.
I just use presta now as they are easy to get hold of.
Posted : 30/01/2016 9:52 am
Was thinking the same things as my rims have Schrader size holes.
Would Presta valves seal ie be wide enough?
Posted : 30/01/2016 10:14 am
Can you remove the inner core on a Schrader valve?
Posted : 30/01/2016 10:17 am
Not a clue.
My other rims have presta valves with removable cores and I still just pop the tyre off a tad to get the sealant in. Prefer to know the levels and remove any sealant blobs.
Posted : 30/01/2016 10:21 am
yes (with a tool or one of those funky caps with the tool on top), and I've run tubeless with Schrader valves, worked well.
I've got 4 or 5 of these knocking around in various places
Posted : 30/01/2016 10:22 am
Schwalbe tubes have removable cores and you can cut up an old one rather than buying a standalone valve.
Yes oldnaspit, you need a wee tool
Tbh they work much better for tubeless as you can get more air in, but for some reason crappy presta has dominated
Posted : 30/01/2016 10:23 am
it's not the removable cores (though they wouldn't work without them ๐Ÿ˜‰ ) it's the threaded barrel so they can be clamped to the rim to make a decent seal
Posted : 30/01/2016 10:26 am
losing the barrel ring from the Schwalbe tubes ^^^
Posted : 30/01/2016 10:30 am
it's not the removable cores (though they wouldn't work without them ) it's the threaded barrel so they can be clamped to the rim to make a decent seal
Which all my Schwalbe tubes have... ๐Ÿ˜‰
Posted : 30/01/2016 10:33 am
I've used these on some Dt Swiss Ex500 rims that I'd previously drilled for Schrader tubes.
http://www.chainreactioncycles.com/mobile/no-flats-tubeless-schrader-valve-kit/rp-prod94761?gs=1&gclid=CjwKEAiA27G1BRCEopST9M39gykSJADQyqAl6xY-Z1HdFgZjmkq_vr4n2YvqZBhTG2jnSdBpk9hEgxoC2w7w_wcB&gclsrc=aw.ds
Work fine. Removable cores and come with the tool.
Posted : 30/01/2016 10:42 am
Cheers one and all. That another job for this weekend, tubeless conversion.
Posted : 30/01/2016 10:45 am
stans used to do a [url= http://www.notubes.com/Stans-Standard-Valve-Stem-Problem-Solver-P624.aspx ]problem solver valve[/url] for schrader size holes whether you can still get them (though they say they are available ๐Ÿ™„ ). Other wise continental presta road tubes come with removable cores and can be made to work.
This valve *will not work* to convert a non-tubeless rim to tubeless
worked fine for me on a set of dt 5.1 and single wind of yellow rim tape.
Posted : 30/01/2016 11:00 am
Got some motorcycle valves kicking around. They are tubeless of course. I might try one on an old rim
Posted : 30/01/2016 11:08 am
Used a split tube method with schrader valve.
Apart from getting the bead to seat I have not had any issues.
Posted : 30/01/2016 2:30 pm
Yep. Been using them tubeless for years. The little Stan's refill bottles fit perfectly in the valve. Much better than Presta.
Posted : 30/01/2016 2:52 pm
^ as above, cannondale came with them, far superior to presta, I'll swap them all eventually.
Posted : 30/01/2016 2:56 pm
If you've got a Schrader sized hope defo get Schrader tubeless valves, problem solver for using pests valves is a joke surely !
Posted : 30/01/2016 11:32 pm
The Schrader valves in mine were cut out of old innertubes. Work fine with gorilla tape.
Posted : 31/01/2016 1:10 am
Why would it bother anyone?
Think about this:
Every single car on the road in the whole world has 4 tyres set up tubeless with a schrader valve....!
Posted : 31/01/2016 9:19 am
I very much doubt that!
Posted : 31/01/2016 10:29 am
schraeder valves make more sense for wide rims, easily removable core and a bigger whole for blasting air through to help seating the tyre.
Posted : 31/01/2016 2:43 pm
