Anyone gone tubeles...
[Closed] Anyone gone tubeless on Alex Volar rims?
Have some Alex volar 2.5 rims which when new I contemplated setting up tubeless but I couldn't get the tyres to seat into the rim at all. Even with tubes as soon as you let the air out of the inner tube the tyre just drops off the rim.
Just wondered if anyone had successfully managed to set them up tubeless and if so how they go on for burping.
Posted : 18/10/2016 8:56 pm
Yip, gorilla tape. HR2. Sealant. Track pump. Inflated, no problem. Holds air fine.
Posted : 18/10/2016 9:32 pm
 mboy
You must be using very loose tyres
I had some, and all the tyres I tried were pretty tight and sealed well in conjunction with 2 wraps of stans yellow tape.
Posted : 18/10/2016 9:38 pm
Thanks for the replies. The tyres are schwalbe Magic Mary and Nobby nic. They do seem very loose. Certainly don't need levers to get them onto the rims.
Posted : 18/10/2016 9:48 pm
I tried a hans dampf on my old sun ringle rim (tubeless). It was very slack. Gave up. Washed tyre, boxed it up. Went back the shop. Swapped it for a vigilante.
It went on no bother.
Some tyre rim combinations are defo non compatible. In my opinion. I had a stans arch rim, what I could hardly get a tyre onto. Even with lube. It would go on with a lot of swearing. Broke decent tyre levers too. Would never sit properly on the rim. Ran like it was buckled, would never centre. I hung it up in the shed and bought the alex.
Posted : 18/10/2016 11:12 pm
Cheers. Will give it another go with some more rim tape.
Posted : 19/10/2016 12:52 pm
