Anyone fitted a 203...
[Closed] Anyone fitted a 203mm shimano brake to the new fox 36
Hi guys
trying to work out what adapter i need to use a 203mm disc (shimano caliper) on a new pair of fox 36.The mount is 180mm as std .
many thanks
Posted : 20/09/2014 2:17 pm
Bump
Posted : 21/09/2014 6:57 pm
I would normally say you need a +20 adapter ie a 160 to 180 one but it might not be quite right.
Posted : 21/09/2014 8:41 pm
Tried that ,shimano 160 to 180, didnt work
Posted : 21/09/2014 8:48 pm
Could add a few washers for the extra [s]3mm[/s]1.5mm?
Posted : 21/09/2014 8:51 pm
Good suggestion of Hope PM to PM 160 to 183mm adapter here: http://forums.mtbr.com/brake-time/post-post-adaptor-180-post-203-rotor-921446.html
Posted : 21/09/2014 8:54 pm
I have tried to use a avid 203 one this doesn't work I have a shimano post to post mount this works fine
Posted : 21/09/2014 8:57 pm
Have they changed since 2013?
I used a front Post mount to post mount 203mm adaptor like this one....
[url= http://www.chainreactioncycles.com/mobile/shimano-mount-adaptor-front-post-to-post/rp-prod13747 ]Link...[/url]
In 203 flavour.
Posted : 21/09/2014 9:26 pm
Thanks to andyl , the hope 183mm worked a treat , thanks
Posted : 19/10/2014 6:29 pm
