Hi all
I've got a Thule Euroclassic which is a great bit of kit. It's seen a lot of (mainly wet) use now though and there's a bit of corrosion in the light units, with resulting temperamental lighting. I notice the new ones are sealed LEDs, anyone done a conversion from the original bulb version?
Posted : 15/09/2012 5:36 pm
Use a fine grade sand paper on the terminals they will come out like new.
Posted : 15/09/2012 8:34 pm
Aye that's what I've been doing. It's more the fact I have to do it at all, I'm assuming the LEDs are sealed units.
Posted : 15/09/2012 8:48 pm
LED bulbs good, use them in trailers but prob only better in that less prone to failing from vibration.
Corrosion wise clean up terminals, good dose of WD40 then seal the light unit with silicon grease
Posted : 15/09/2012 10:10 pm
