Preferably dual position.
Is this possible to do as a DIY job?
If so what's required and how much are the parts.
I had a sektor 150mm coil and preload cap in my 20mm axle revs...
awesome fork! so much better than it was air.. sold it now as I have a bigger bike and moved to vanilla 36's.
I had a sektor 150mm coil and preload cap in my 20mm axle revs... I'd imagine you could use a dual position or even u turn, but I wanted simplicity.
Yes do-able, however you'll loose 5 to 7mm due to the neagtive spring assm.
I did mine with a DP coil beacuse you get all the parts in one package. Was pretty easy and around £40. Only thing to note was that I had to reuse the bottom out bumper as a spacer on the rebound shaft as the CSU extended further than it should with the coil in it (beyond 150mm) because it didnt have the negative spring on the other side, which worried me a little. I added the bottom out bumper to the rebound shaft and it worked perfectly. Not sure this is recommended though... but worked for me.
