Anyone bought the I...
[Closed] Anyone bought the I-Spec Direct Attach Covers recently?
Changing brakes this weekend and have discovered although I already have the ispec shifters, I managed to loose one of the long square headed nuts after removing the brackets to fit the shifters onto the older Hope direct mounts.
Does anyone know if the ispec direct attach covers come with the long square nut from CRC http://www.chainreactioncycles.com/shimano-xt-m780-i-spec-direct-attach-cover/rp-prod67257#bazaarvoice_reviews_tab
Can't see them in the pic but I'm hoping they are included?
Thanks.
Posted : 19/12/2014 11:50 pm
I bought that kit earlier in the year and wasn't sure of the part you are missing, couldn't remember needing it. Having looked at the [url= http://si.shimano.com/php/download.php?file=pdf/dm/DM-SL0001-03-ENG.pdf ]User's Manual[/url] I assume it's the bolt required to mate a new type shifting lever onto a conventional brake lever (page 7).
I had new style levers/shifters so didn't need this part, but I've just checked my box of spares and it looks like it was included in the kit. Is it this one?
If so, I can probably just send you mine as I have no need for it.
Posted : 20/12/2014 10:07 am
Im pretty sure they come with the bolt and square nut your talking about otherwise i would have had to get them separately when i changed my brakes and shifter (which i cant remember doing)
Posted : 20/12/2014 10:15 am
Cheers lads.
I ordered them just in case.
Thanks for your kind offer chored, much appreciated. I may well take you up on your offer if the mounts don't come with the nut in your picture.
Thanks again.
Posted : 21/12/2014 11:55 am
CHORED!
Do you still have these two bolts kicking around good sir? I'm new on this forum and joined simply to try and source these for my i-spec b/hope combination as I'm missing them also.
When I figure out how to PM you I will, in the meantime... let me know, would be awesome to solve this problem ๐Ÿ™‚
Ant
Posted : 02/01/2015 5:30 pm
I've added my email address to my profile. Drop me an email and I'll pop them in the post.
Posted : 02/01/2015 6:45 pm
Have Emailed, let me know you have it.
Thank you!
Posted : 02/01/2015 7:12 pm
