any reason not to u...
[Closed] any reason not to use a formula adaptor on shimano brakes ?
i dont think so just wondered because ive just fitted slx brakes to my fox forks post mount and its a 180mm rotor so i tried a post to post shimano one and it put the caliper at a silly angle with the hose going off to the rear ish so i tried my different profiled formula post to post 180 and it fits much better and at better angle
just wasnt sure why shimano do it like that and if i shouldnt use the formula one
cheers
Posted : 26/11/2009 5:04 pm
Did you definitely fit them both the right way? Post to post ones are essentially a spacer so not sure why it would matter?
Posted : 26/11/2009 5:06 pm
yes mate its just they are quite different in shape the formula one is much better
Posted : 26/11/2009 5:14 pm
Posted : 26/11/2009 5:17 pm
its a lesser angle on the formula as it is thicker at the bottom than the shimano one so puts it in a different place on the rotor but its still central on the brake area. just a bit further round. and the hose sits much better
Posted : 26/11/2009 5:18 pm
I had a Hope one on my Avid brakes and it meant that not all of the pad would contact with the disc - worked ok for a bit but once the pads wore down a bit they pretty much stopped working.
As long as you get a decent amount of pad contact I can't see the problem.
Posted : 26/11/2009 5:20 pm
it appears to be in contact as good as the shimano one so i'll leave it as it sits better
cheers
Posted : 26/11/2009 5:32 pm
