Any off-piste at Sh...
[Closed] Any off-piste at Sherwood Pines?
Up close to a Pines for a few days and wondered if anything other than the red route and jump/freeride park section?
Ridden the red a few times plus the play area. Have explored a little off track, but most seems to be more cut theoughs between areas of the Red/Blue? Found one section that followed a gully along tonte lower freeride area/railway type bridge. Struggled to find any more!
Posted : 17/08/2017 1:33 pm
I remember a few XC bits on the other side of the train track just after the freeride park. Nohing particularly exciting though.
Posted : 17/08/2017 1:38 pm
There are bits and bobs dotted around which can be used as extensions to the red. Most used to be on Strava, but seem to have disappeared of late.
If you can somehow find them on strava, then the bombholes, flashhearts folly and the night garden segments are a good start.
Posted : 17/08/2017 1:57 pm
 rone
Loads, you need to push out to the desert. Be careful though, some good stuff dropping down from the old train lines that can be a bit necky.
Also good stuff west out of the park towards Mansfield/Southwell road.
There are also a few nice bits southwards towards Rainworth.
We are talking the outside of the actual park though.
Posted : 17/08/2017 2:03 pm
Cheers!
Thought I'd seen more on Strava last year than I could find this year!
Problem is with strava at a trail centre (as any trail-centre) is the amount of segments, that just overlap each other foe the same route!!
Sounds like it's worth an explore though
Posted : 17/08/2017 3:24 pm
