Any heavy guys ridi...
[Closed] Any heavy guys riding a Turner 6 pack?
If so, what weight spring are you running. It's starting to look like my 700 lbs/in is looking a bit weedy!
What's the heaviest spring for a 2" DHX 5.0?
Posted : 20/02/2010 10:44 pm
Is that the same size i2i shock for a '06 RFX?
I was thinking of going over to a coil shock for mine,as at the moment I run a DHX5 Air,& have to run it at fairly high pressure,270PSI,to achieve the correct sag.
Posted : 20/02/2010 10:50 pm
My i2i is 190 mm on a 2" stroke shock.
Posted : 20/02/2010 11:09 pm
