need something efficient for when out and about ...anyone know of something better (before I order)
thanks
Bill
The proper Morph is better- I found the mini morph to be only a bit better than a normal mini pump (it's still better though). The proper Morph is one of my favourite bike purchases last year.
i use a little alloy lezyne one, it is very good to be honest.
comes with the old type hose connecter.
Lezyne version of the mini morph (not sure of the name off hand) hv version blows up a 29er tyre double quick time
Blackburn Mammoth (older model).
Lezyne Alloy Drive, simmillar to the one Ton linked above. Very well made, & the reversible connector hose is spot on. Loads less faff than these press on jobbies. 90psi but mine has no probs getting road tyres to 90+.
You still after that stem raiser thing you posted for earlier ?
I've just dug one out in the garage. 1" quill affair with a 1" - 1 1/8" shim.
I found the mini morph to be perfect
Topeak Master Blaster Speed Pump - CRC for around £15 - gets my road tyres over 100psi easily and fits both PV and SV. It's a bit longer than the minis but still fits in my camelbak for MTB or downtube for the commute (so cheap though I have two)
thanks guys
takisawa ygm
Truflo Evolution is the same sort of idea but shifts more air and is better put together. The Plus model comes with a predictably inaccurate guage too.
