Another "what&...
[Closed] Another "what's my old bike worth" thread..?
So, Tracy has been sat in the garage since the summer, bearingless in part due to a ham fisted and sleep deprived attempt at bearing replacement.
I know it's not worth much but what are the collective thoughts on the below?
It's got a new BB, new rings, new pads ready to be fitted.
2010 Intense Tracer VP (140, 150 mm adjustable travel)
2010 Rockshox Lyrik RC2DH @ 160mm
XT groupset
Avid Elixir CR 203/183 brakes
Thomson stem, Easton ea70 monkey bars
Hope Pro11 / Stans Flow wheelset
Wellgo magnesium flat pedals
Maxis minion / cheap bontrager tyres
Rough weight 32.5lbs in large
And I'd replace the bearings obviously ...
Posted : 08/03/2017 10:46 am
I'll give you £50... 😉
Posted : 08/03/2017 10:49 am
Swap for your place in fulwood? 🙂
Posted : 08/03/2017 10:51 am
Nice frame ! Assuming its all in decent condition £500-600 ? The wheels, forks, stem and bars I could be interested in if you splt.
Posted : 08/03/2017 10:54 am
^ yeah that's kind of what I was thinking although I might have to spend £100 getting the lbs to sort out the bearings.
I might indeed look at splitting actually.. rims have a small dent each but bearings are fine. It's just the faff of then trying to sell all the old 9 speed drivetrain that no one wants!
Posted : 08/03/2017 10:57 am
Tracy
My main concern is who is Tracy?
Posted : 08/03/2017 12:30 pm
Yeah, she might be rubbish at changing bearings but that seems like excessive punishment to me.
Posted : 08/03/2017 1:36 pm
The fact the OP called it that would deserve a 20% discount in my view...
Posted : 08/03/2017 1:43 pm
Duhhh! What would you call an Intense Tracer if not Tracy then?
Although the new ish carbon Tracer is called Troy..
So.. £500 - £600 do we think. I was hoping for a bit more but obviously it has outdated and thus dangerously small wheels 🙄
Posted : 08/03/2017 1:49 pm
Some nice kit on that, I'd definitely split it.
Maybe £800 if not.
Posted : 08/03/2017 1:51 pm
I've seen quite a few on pinkbike for 7-800 but they don't seem to necessarily go for that.
Not sure if splitting is better or not?
I mean, what £80 or less for the wheels, £130 for th forks, brakes next to nothing, drivetrain the same, frame maybe £250 if I get the bearings sorted?
Posted : 08/03/2017 2:20 pm
There's an e in Tracer so it should have been Tracey but then why would you name a bike after me 🙂
Id split it, always ended up with more that way
Posted : 08/03/2017 2:30 pm
^ my boss is called Tracy too. It gets awkward :-/
Posted : 08/03/2017 2:45 pm
I'm with Jambalaya, £500-£600.
Posted : 08/03/2017 3:33 pm
is your boss in the garage too?? 😆
Posted : 08/03/2017 4:04 pm
off-topic but £100 to replace bearings...Why so much?
Posted : 08/03/2017 4:59 pm
^^ well I think a full set of bearings is £50 and as I recall the labour rate about the same last time I had them done ..
Posted : 08/03/2017 5:15 pm
Yeah you might be right actually.
Posted : 08/03/2017 5:16 pm
