Another Fork Offset...
[Closed] Another Fork Offset question
My FS 100mm 29er currently has a 55mm offset.
If I replace that fork with a fork that has 51mm offset how would that affect how the bike handles? Head angle is currently 69.5 degrees if that has any bearing on things.
Sorry I’ve tried searching and keep finding conflicting information...
Posted : 08/11/2019 10:10 pm
Are you sure it’s 55mm offset? That’s unusually long! The slightly shorter offset will make the steering very slightly calmer.
Posted : 08/11/2019 10:15 pm
Yep thanks. It’s a Lefty 2.0 with 55mm but thinking about sticking a rockshox SID on it at 51mm.
So steering would be slightly more stable and less responsive?
Posted : 08/11/2019 10:18 pm
Pretty clear video here that explains what will happen
Posted : 08/11/2019 10:30 pm
“So steering would be slightly more stable and less responsive?”
It’s not a big difference - like slackening your head angle by half a degree in your case (which you can get a feel for by adding 10mm more sag at the back or 10mm less at the front or 5mm at both ends).
Posted : 08/11/2019 10:43 pm
Thanks guys. That video was very helpful.
I’m now an offset wizard
Posted : 08/11/2019 10:44 pm
Leftys tend to have short A-C lengths, so replacement likely to be longer, so HA likely to slacken a bit too.
Posted : 09/11/2019 3:10 pm
