Any good alternatives, can't be anything fancy at a guess? Who makes the Stans?
Someone mentioned 3M Mylar tape on this thread...
http://www.singletrackworld.com/forum/topic/seriously-peed-off-with-my-new-stans-355-rims/page/2
Tempted to give it a go as it's pretty cheap on eBay
is this any different to the tape that comes with stans rims?
http://www.chainreactioncycles.com/Models.aspx?ModelID=38824
That stuff from CRC is still way over-priced
[url= http://www.directa.co.uk/site/scripts/product_browse.php?product_id=1940 ]36p/yard Versus ~2p/yard[/url]
same stuff
your link is to non adhesive tape
so it is 😳
I meant this one
http://www.directa.co.uk/site/scripts/product_browse.php?product_id=1953&category_id=306
£15 minimum order value tho mate
I meant it more as guide of the sort of stuff that you need
[3m cross weave type stuff] rather than a recommendation of where to buy from
Somewhere local to you is bound to stock that sort of stuff
150m of it direct from 3m for £4.44 - 25mm may be a bit wide though
http://www.3mselect.co.uk/p-1711-3m-reinforced-cross-weave-filament-tape-8959-25mm-x-50m-3-rolls.aspx
Black gaffer / bodge tape work for converting non tubeless rims to tubeless, Just start before the vale and finish after, making a hole for the valve.
Paul
Half an inner tube £2
I've been using electrical tape for the last 6 months and no problems at all. 3 layers deep, nice and tight and started before the valve and finished after.
b+q have 25mm wide clear gaffer tape for £4ish,dont think it will
work on the narrower rims but fine on flows!
gorilla tape...
