Alternative bite va...
[Closed] Alternative bite valves for a dakine bladder
[#2531339]
Is there any other make bite valves that will fit on my dakine bladder as the original has been crap! And is now broke after just 6 months, shame cos the bag itself is the best i'v had, any suggestions much appreciated.
Posted : 05/03/2011 11:26 am
Yep, I'd like some suggestions too, mine is just too stiff to operate with gloved fingers and leaks if you don't close it off.
Posted : 05/03/2011 2:12 pm
I have a used once Dakine reservior (3L) for sale, should you be interested.
Email in profile.
Posted : 05/03/2011 5:21 pm
Presume its a Hydrapak bladder like my nomad:
http://www.chainreactioncycles.com/Models.aspx?ModelID=57592
That one seems to work better.
Posted : 05/03/2011 5:29 pm
Their hoses are a bit crap too, swapped mine straight away for a Camelbak set up.Heat the hose in hot water and it'll fit on the bladder fine.
Posted : 05/03/2011 7:39 pm
That valve (on CRC) is the one I have trouble with. Its too stiff turning from open to closed, especially when left for any length of time in the cupboard.
Posted : 05/03/2011 9:02 pm
Cheers all, just ordered a surge valve, hopefully thats better, mtbtomo, thats exactly what mines like, nearly breaking my teeth trying to pull it out! can't leave it out cos it leaks! dakine nomad, brilliant bag, poor bite valve.
Posted : 06/03/2011 11:33 am
 jonb
I got a Camelbak one to fit mine. Top tip os to dip the end of the hose in boiling water for a few seconds to soften it. Much easier to get the new bite valve in that way, especially if it is a bit too large.
Posted : 06/03/2011 12:36 pm
Try and find a Nalgene bite valve, especially the ones with the magnetic clip, they are the best bite valve I have used.
Look [url= http://www.facewest.co.uk/Nalgene-Bite-Valve.html ]here[/url]...
Posted : 06/03/2011 12:41 pm
Shaggi, just so there's no confusion, its the Surge valve I have - it twists shut. Its too stiff to twist between closed and open, and its been that way almost from new.
Posted : 06/03/2011 2:22 pm
