Are the PCD's ...
[Closed] Are the PCD's on an XTR (M970) crank the same as others?
[#2531355]
Just wondering about purchasing an XTR crankset and when looking at chainrings on CRC I notice middleburn list a seperate chainring/s for XTR and I was wondering why?
cheers
Dave
Posted : 05/03/2011 11:43 am
I thougth that its only the Granny ring that has a weird offset.
Posted : 05/03/2011 11:45 am
PCD is the same as std on mine mate so can use any rings on the 970's but you will need some washers/spacers to get chainline right if you don't use xtr rings (which have some sort of built in offset!)
Posted : 05/03/2011 11:57 am
Only need 2mm spacers on the granny ring if you don't use M970 rings, use what you want otherwise.
Posted : 05/03/2011 12:02 pm
Perfect
cheers
Guys
Posted : 05/03/2011 12:18 pm
The specific rings are for the 960 chainset.
Posted : 05/03/2011 1:20 pm
ahhh that makes sense now
Ta
Posted : 05/03/2011 1:56 pm
