Allan key skewers
[Closed] Allan key skewers
Just had a set of the above delivered to put on my pub-bike, in the probably vain hope that my wheels are less likely to get nicked.
Just noticed some small print on the packet which, "PROHIBITS skewer use in conjunction with front disk brakes..... Stopping force can cause bicycle fork dropout if safety skeres are not in use...."
Is this right? Or are they just covering their @rses?
Are allan key skewers more likely to work loose than QR skewers?
Posted : 23/07/2009 12:42 pm
Dunno. I got some second hand Halo ones for the bike for Mrs Atlaz. She's not likely to shake them loose in a year of riding so I wasn't overly concerned. They do seem a little more prone to loosening but I suspect that's down to me not being hard enough tightening them.
Posted : 23/07/2009 12:45 pm
 Olly
ive been using them for aaages.
you can do them up much tighter than QRs
i suppose, if QRs are use properly, the strain forces actually tightens them, as you SHOULD be putting the cam over the "hump"
(if that makes any sense)
allen ones dont have that.
ive had no problems, keep and eye on them if your worried :s
Posted : 23/07/2009 12:55 pm
 Tim
I think its just an arese covering thing in case you dont do them up tight enough
true, but only for some types of skewer - lots of aftermarket ones dont use an 'overcam' design like shimano use, so they can only get looser.
Posted : 23/07/2009 12:57 pm
Had them on my bike for a long time - no problems yet with this.
Probably easy to overtighten if any thing.
Posted : 23/07/2009 12:58 pm
 Tim
They do grind away at the dropouts if your not careful (as QRs dont actually rotate)
Posted : 23/07/2009 1:01 pm
Cheers chaps - these are Halo ones and have a tab which grabs the bottom of the dropout to stop rotation, in theory.....
Feel a bit happier about fitting them now ๐Ÿ™‚
Posted : 23/07/2009 1:09 pm
