Am running alfine hub on 26er rim. front chainring is 36 teeth, rear cog is 23, i want to gear it by changing out the rear sprocket, changing to a 20 or 18 is that going to gear it up or down? cheers
Posted : 25/09/2010 5:31 pm
smaller rear sproket = higher gear - same as any other set up
With an 18 the ratios are almost identical to an 11/34 caseette
Posted : 25/09/2010 5:33 pm
Thanks have just ordered a 16 ,)
Posted : 25/09/2010 6:27 pm
online calculator [url= http://www.onehillside.com/hub.html ]here also[/url]
Posted : 25/09/2010 7:00 pm
