Hi my mate needs a new drivetrain for his winter road tour bike and is thinking of a internal geared hub is the alfine 8 good enough and does it have a decent spread of low for fully loaded and high for a bit of speed. Also can you run one with a double set of rings up front. Cheers
Don't see why not, double ring fine with a tensioner. The jumps might be too big for a roadie IMO.
I wish they'd release a close ratio alfine for roadies 🙁 I'd get one and belt-drive it.
If you do go down the dual ring route, you'll have a mish mash of shifters for either flat or drop bars as there isn't a 'front' shifter for Alfine...... that might not be the only problem though - are there issues with chain-line etc?
I use one for commutting. Range is spot on. It can get me up as good a hill as you can throw at me (Brecon Beacons, Newcastle, Wylam) without spinning out too much on a good down hill. So that's a range of ~6 mph stood up in bottom gear to spinning out at 35-40 mph.
The chunky range is annoying though. Comfortable psnning speeds on ym gearing are 16 mph or 19 mph, where my average/happy cruising speed is somewhere in between.
The shimano alfine/nexus chain tensioner has a large spring and throw on it for exactly that purpose. You shouldn't need it though.
you can have double rings - you need to use the alfine tensioner to take the slack up.
as for ratios you can use this to look at ratios etc
http://www.sheldonbrown.com/gears/
I have one on a Singular Peregrine setup pretty much the same as Jon Taylor's (except mine's shinier).
I've ridden home from the Lakes over Hartside Pass on it and its great.
[url= http://farm5.static.flickr.com/4020/4619320024_b2ae67b48c.jp g" target="_blank">http://farm5.static.flickr.com/4020/4619320024_b2ae67b48c.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ir_bandito/4619320024/ ]DSC_0871[/url] by [url= http://www.flickr.com/people/ir_bandito/ ]ir_bandito[/url], on Flickr
Cheers chaps what size cogs and rings are you using btw
I'm using a 45t front and 18t (IIRC?) rear. It originally had 16t on the rear but I put the 18t on for a trip from Kendal to Swansea via the Brecon Beacons. I'll check once home.
p.s. His is shinier.
I rode my fully loaded tourer up nearly everything apart from a 25% climb at the end of a 100Km day of ridding as I thought my head was about to pop. I also managed 40Km in an hour with a monster tailwind on another day of the ride. I was spinning pretty hard but not spinning out.
I'm running 18 39 I think (will check). Think I might drop it a bit if I tour again but unladen it's fine. The only thing I found a bit annoying was having to back off almost to the point of stopping pedaling when changing down under load. If it was really steep it did feel like I was going to grind to a halt, but I got used to it.
I've said this before and at the danger of sounding like a broken record, the alfine needs thick spokes, otherwise the vibrate in the flange hole (fnar fnar) and snap at the elbow after x thousand miles of use!
I've used one for commuting/light touring for a year and a half now. Perfect for theses uses. Haven't done any maintenance in ages! I use the JTek bar end shifter.
However, I've taken it on the sunday club run a few times and the gear jumps are annoying when riding in a bunch as 1 gear is too easy and the next is too hard at a specific constant speed.
Heh nice D, you're turning into a roadie 😎
Oh damitamit I didn't know bar end shifters worked with them 😉
45 front and 20 rear on my Roadrat. Perfect for commuting but I'd want to go a tad lower if touring, and maybe a tad higher (45:18 perhaps) if it was a drop-bar road bike.
I've got one of the Alfine tensioners so was thinking about using a double up front but haven't got around to trying it.
firestater, only this special one works with it: http://jtekengineering.com/jtek_bar-end_shifter.htm
I got mine from PlanetX. Not sure they still sell them.
Ah not as good as hoped re the shifter , thanks all
On-one's doing an amazing deal on the Alfine right now...
[url= http://www.on-one.co.uk/i/q/ZXHUSHALF8KIT/alfine-8-speed-hub-bundle ]This...[/url]
[url= http://www.on-one.co.uk/i/q/WRSHAL501/shimano-alfine-whs501-rear-wheel ]...and this if you can't be arsed to build a wheel!! 🙂 (costs 215 including all the gubbins)[/url]
Hey ir_bandito, what kind of shifter are you using there?
The alfine hub and bits is even cheaper at Rosebikes.co.uk (and it's definitely the better 501 model)
shermer - it's a Versa shifter. Like these
http://www.planet-x-bikes.co.uk/i/q/BLVEVRS8/versa-vrs-8-brake-levers-pair-for-alfine-8sp-
Thanks Jon! 🙂
Hey Mackem- that is phenomenally cheap!!! It does say that it's only suitable for vertical drop outs though. Maybe there is a way around that?
Yep, you can buy the horizontal locking washers for about £4. Nice...
Nearly just bought a built wheel from rosebikes then realised it a 24 spoke one not for my fat ass lol
