Alfine 11 rotary sh...
[Closed] Alfine 11 rotary shifters ?
I would like to get an Alfine 11 - possibly on existing bike or on ready made bike. Not just yet, but in a year or so.
However, I believe Shimano do not sell rotary shifters for it.
I would only have rotary shifters. So, does anyone know of any rotary shifter that would work with Alfine 11 ?
Has anyone actually fitted rotary ? Was it successful ?
All info much appreciated.
Posted : 27/05/2012 5:44 pm
Due to cable pull being different to most / all other systems I think you'd only be able to use the shimano specific one.
Microshift do some other alfine / nexus shifters so maybe they'll do one at some point
Posted : 27/05/2012 5:48 pm
The alfine 8 has the same cable pull per click so that would get you 8 of the 11, youd have to pull one apart to see if it would be possible to 'manufacture' some extra clicks. Basically your going to be stuck with a trigger i reckon.
Posted : 27/05/2012 6:21 pm
Thanks all - at least I now know the current situation.
I'll keep a lookout for developments ...
Posted : 01/06/2012 9:38 pm
Is the shift indexed at the hub (as Rohloff), or at the shifter? If it's the former, it should be easier to adjust a grip shifter for an 11-speed Alfine; if the latter, it could be a bit more tricky.
Or you could hang on and see about this Di2 electronic shifting that apparently is on its way for Alfine.
Posted : 01/06/2012 9:41 pm
