Air Spring Volume T...
[Closed] Air Spring Volume Tuning Kit for Fox Float CTD - worth it?
I find that my shock feels a bit divey and bottoms out easily.
I'm thinking of experimenting with the volume tuning kit before turning to costlier alternatives.
Has anyone tried them? Are they worth the 30 squid?
Posted : 07/03/2018 6:48 pm
Check the spec before you buy to see whats inside already, but yes, assuming its not got a whopping spacer in it already its worth it.
Posted : 07/03/2018 7:52 pm
It's a hell of a lot of money for a few bits of plastic but yes, it does help.
If it needs a service then just get it Push'ed  - made a huge difference to mine.  You might be able to get them to throw in some volume spacers (or at least not charge you full retail on it).
Posted : 07/03/2018 8:17 pm
What is this Push’ed and how much would it set me back?
Posted : 07/03/2018 8:57 pm
Darn, just opened up my shock and it turns out that I already have the second to largest spacer installed. Do you think that getting the size larger will make a tangible difference (0.8 cubic inches vs 0.92)? Also, is it possible to combine multiple spacers? The smallest one looks like it may fit inside the large ones.
Posted : 07/03/2018 11:18 pm
